starter removal?
Old Nov 26, 2008 | 07:09 PM
zach113092's Avatar
starter removal?
my starter died and i am trying to remove it but i cant get it out, it is stuck in there because the exhaust piping is blocking it from coming out, how can i get it out?
Old Nov 26, 2008 | 07:19 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
Re: starter removal?
If the exhaust manifold is in the way the only way to get it out is by either taking the manifold completely off or loosening it and trying to work it off but when mine went the first time the whole manifold was removed. Now that I have headers it comes right off. That by itself made the headers a good investment.
Brandon
Old Nov 27, 2008 | 12:30 AM
zach113092's Avatar
thanks, this is gonna suck..
Old Jan 1, 2009 | 12:54 AM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
Remove the solenoid housing from the starter first, and you will get it out.
Old Jan 1, 2009 | 03:23 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I've never had to take any exhaust apart to get mine out... manifolds or headers. Just wrestle with it a little and twist it around and it will eventually come out. If that won't work, dropping the Y-pipe would be easier than taking the exhaust manifold off IMO....
Old Jan 1, 2009 | 10:18 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
if youve never done exhaust work dont take off the manifold..... your bolts without being heated will likely snap causing irritating exhaust leaks so on....... anyways as others said it doesnt need to come out.... take a big pry bar and a block of wood and pry the y pipe over a little while youre wrestling it out.... they are a bit of a pain but no big deal...
Old Jan 3, 2009 | 01:01 PM
Pocket's Avatar
Car: 91 Trans Am
It will fit, just have patience
You dont have to beat/bend/remove anything
Ive done it more than once
Old Jan 3, 2009 | 01:24 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
as he said thats probbly the easiest way, thats how i did mine
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
