installing comp cam...ran into problem help
Old Oct 5, 2009 | 01:42 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
i got a comp cam and lifter set for my 91 z28 305 5sp. the cam ratings are at
Advertised Intake Duration 280
Advertised Exhaust Duration 280
intake valve lift 480
exhaust valve lift 480
lobe separation 110
i was looking around for a long time asking many questions and i came to this one. but i got into my motor to install it and i then realized there were roller lifters..... this is a flat tappet cam/lifter set. i could not afford the roller. the roller lifters are about .5 inch taller then the tappet lifters. will this affect the lift or anything? please help
Old Oct 5, 2009 | 03:25 PM
mikesz1984's Avatar
Car: 1984 z28
Re: installing comp cam...ran into problem help
i dont beleive it will affect the lift, but you will need to get new push rods for the motor. The push rods from the roller lifters will be to short.
Old Oct 5, 2009 | 05:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Roller pushrods are 7.200" ; flat tappet are 7.800" long
Old Oct 5, 2009 | 05:32 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
my buddy just got a set of 7.794" will those work? he said he would give them to me? or would those not work?
Old Oct 5, 2009 | 09:12 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i would say that would do fine ,but you will just have to test fit them to make sure you have correct alignment.
Old Oct 5, 2009 | 10:24 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
ok cool. they fit i checked. one last problem lol. ran into a few. the plate that holds the old cam in place. it does not fit the new one. what is this called and where do i get one that fits? thanks for the fast response guys. much appreciated.
Old Oct 5, 2009 | 10:36 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
With a flat tappet cam you wont use the plate. IIRC you will also have to get a new timing set because the factory roller cam has a lip that goes in the retainer plate.
Old Oct 5, 2009 | 10:49 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
so what is gonna hold the cam in place?
Old Oct 6, 2009 | 12:05 AM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
info please
Old Oct 6, 2009 | 02:01 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
A flat tappet cam has a "angle" ground on the cam lobes so the pressure of the lifters drives the cam back into the block.
A roller cam cam has a flat lobe for the roller lifter wheel so there is nothing to stop the cam walking forward out of the block .The factory used a cam with a grove in the front so a retainer plate could hold the cam in
Old Oct 6, 2009 | 02:04 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
And the cam timing gear has a different bolt pattern
Old Oct 6, 2009 | 07:06 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Cam gear has the same bolt pattern.
Old Oct 6, 2009 | 07:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Holes for the cam gear bolts on a flat tappet cam are out where the retainer grove is on a HR cam.Bolt pattern and pin are moved in on HR cam to allow for groove.
Put the two gears side by side or try a flat tappet gear on a roller cam; you will see the difference.
Old Oct 6, 2009 | 10:40 AM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Here i am ready to drop about a 1000 bucks to have a roller set up in my Flat tappet block, and i see all these people using FLAT TAPPET CAMS in there ROLLER BLOCKS. ARRRRRRRRRRRRRRRRRGGGGGG.
Rant off.
Old Oct 6, 2009 | 12:16 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ill have to check that out. I never noticed a difference.
Old Oct 6, 2009 | 10:45 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Actually, flat tappet cams can be either what we refer to as "front walkers" or "back walkers", depending on the how the block was machined at the factory.
Handling the "front walkers" is usually done with a thrust button. Those come in three basic variations; plastic, aluminum and roller types. I prefer the roller type since I've seen the plastic type wear excessively and have seen the aluminum type actually drill through the timing change cover.
Handling" back walkers" is done with a bearing placed between the cam gear and the block. Cloyes makes a timing chain set that is already machined to account for the thickness of the Torrington bearing and even comes with the timing chain set. It's a simple bolt on. The best type is the three-piece Torrington bearing.
Hope this helps.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
nuggie
Aug 25, 2015 01:27 PM
Fronzizzle
Aug 17, 2015 02:52 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
