High Performance Throttle Body?
Old Mar 3, 2011 | 10:38 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Besides the Hypertech chip i have id like to know some simple engine upgrades i could do to my tpi system. I have an MSD box, a 160 thermostat, hypertech chip. Eventually id like to install the edelbrock Hi flo system but it is out of my price range. I was wondering if a highperformance TB would do anything for me. And whats the largest Id be able to install with the stock plenum. Thanks
Old Mar 3, 2011 | 10:58 AM
Drew's Avatar
Re: High Performance Throttle Body?
The short answer? no. The stock TB isn't a bottleneck on TPI cars. For that matter, all of the cheap or free mods have very little effect.
Old Mar 3, 2011 | 04:04 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
so a bigger TB would just be a waste of cash?
Old Mar 3, 2011 | 05:59 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
yes it would, like it stated the bottleneck isnt the where the air comes in. Unless you plan on upgrading your entire tpi and porting you wouldnt need a bigger throttle body even then you still wouldnt gain much. What are your goals for your car?
Old Mar 3, 2011 | 07:15 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ditto on dspencer save your cash for mods that work.
Old Mar 3, 2011 | 08:51 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
If anything cut out the bottom of the air intake box. This free mod will let more air into the engine and it works. You will pick up to .3 tenths and 1-2mph. Spend your money on the best upgrade mod which is the exhaust system. Dyno Dons headers and a dual catback Magnaflow exhaust system. Your car will run in the mid to low 13's.
Old Mar 3, 2011 | 10:16 PM
Axle/Gears: 4.11
How?
Old Mar 4, 2011 | 12:31 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Originally Posted by cuisinartvette
How?
umm magic everyone knows this its crazy that the exhaust systems on these cars are that bad
Old Mar 4, 2011 | 03:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I have a 160 thermostat, hypertech chip.
Read bottom of page in link
http://temp.corvetteforum.net/c4/vader86/minormods.html
Old Mar 4, 2011 | 11:46 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
As far as exahust goes i have a complete exhaust from flowtech headers to a flowtech y pipe, flowmaster cat back exahust system, it is 3" from the y pipe to the tail pipes. I also forgot to mention my Richmond 3.73 gears and posi rear end and smaller crank pulley. Thanks to everyone and if anyone else can think of any performance upgrades let me know. thanks
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
