timing 350 tpi
Old Feb 24, 2012 | 09:03 AM
bigcountry1979's Avatar
Car: 90 iroc z
Transmission: 4 speed with od
Axle/Gears: 323 ratio
timing 350 tpi
Have a 90 iroc z with 350 tpi and does anyone know what a good timing degree to set engine to? Also jst bought car with no history bout it so ? Is it has an after market cold air and it does not have a mass air flow sensor! I ddnt no u could do that witout an mas"so anyone know what smeone could have done to it?thks
Old Feb 24, 2012 | 09:42 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: timing 350 tpi
If has a mass air sensor then it is not a 1990. It is an 89 or older.
Old Feb 24, 2012 | 09:57 AM
Car: 90 iroc z
Re: timing 350 tpi
Car is a 90 but not sure bout motor"I no it does not have an mass air flow sensor nowheres lol"any other clues to indentfy its an 89 motor?
Old Feb 24, 2012 | 10:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: timing 350 tpi
A '90 is a speed density system, uses a MAP sensor.
Base timing is 6* BTDC, disconnect the EST/BYPASS connector and set the timing with the engine up to temperature.
RBob.
Old Feb 24, 2012 | 10:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: timing 350 tpi
Can bump that up to 8-10 deg base timing and you should see a mild performance improvement around peak torque rpm. Give it premium gas tho.
Old Feb 24, 2012 | 10:18 AM
Car: 90 iroc z
Re: timing 350 tpi
Thks a lot"ill try that today
Old Feb 24, 2012 | 03:18 PM
Car: 90 iroc z
Re: timing 350 tpi
Had timing ajusted"but feels like throttle is not as quick as b4!slugish feeling on take off but smoothes out bout 2000. Rpms! Any ideas?
Old Feb 24, 2012 | 03:46 PM
svandorst's Avatar
Car: 1992 Camaro RS
Engine: L98 5.7 350
Re: timing 350 tpi
I'm a complete noob when it comes to setting timing and what not. But I have checked it and it is at 6* BTDC. I've got k&n air filters, dual-cat(less) y pipe, magnaflow 3" catback with a qtp cutout..
Would I benefit from setting the timing any higher? I already run 91 octane all the time (best we got at CA pumps).
Old Feb 24, 2012 | 04:05 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: timing 350 tpi
Did you disconnect the EST wire first before setting the timing? It's a single tan wire on the passenger side sticking out of the big wire harness near the A/C Canister.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 24, 2012 | 04:12 PM
Car: 90 iroc z
Re: timing 350 tpi
From wat I hear yes "disconnect that wire b4 setting timing and once timing is set"cutt car off rehook wire n then disconnect battery for a few min"so computer can reset
Old Feb 24, 2012 | 05:10 PM
VincentZ28's Avatar
Re: timing 350 tpi
So what did you set the timing on?
Old Feb 24, 2012 | 07:59 PM
utilityguy2's Avatar
Re: timing 350 tpi
Be aware, if you set the base timing above 6* you are changing the entire spark table by that much. The base timing and the base setting in the programming should be the same - 6* BTDC.
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
