how much boost for a l98
Old Mar 18, 2013 | 02:35 AM
kad5118's Avatar
Car: 91 gta ws6
Transmission: 700 R4 TRANS
Hello every one ,I want to know if any know off hand how much boost can a stock L98 handle
Old Mar 18, 2013 | 09:16 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: how much boost for a l98
4-6 psi without an intercooler
Old Mar 18, 2013 | 10:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Kinda depends on fuel and tuning. Race gas and meth to keep temps down, it could likely take 20 psi and may live. I believe the grenade took over 20 and a small shot to make 730 whp or so. Not quite L98 but stock gm parts.
I raced with a guy who ran low 12's at 115 mph with 12-13 psi on bolt on L98 via procharger.
They can take alot if tune is kept in check. I believe zz3astro here has been 18 psi on his zz4 l98, cant recall if he has zz4 bottom end or just the heads or what.
Old Mar 18, 2013 | 10:49 AM
kad5118's Avatar
Car: 91 gta ws6
ok well the thing that is different in my case my motor has 137,000
Old Mar 18, 2013 | 11:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Depends on how well it was taken care of. Bearing wear starts to become a concern and high loads on crank and rods could wipe bearings out sooner. Some motors live some just dont. Really depends.
I would not be afraid to run 10-13 psi on good gas and intercooled with a good tune, if i felt motor was in good condition
This should have been posted in the power adder section
Old Mar 18, 2013 | 12:10 PM
ninetyone's Avatar
Axle/Gears: 3:42
My brothers 91' 305 tpi ran high 11,s on 4 psi and very little tuning. A v8 doesn't need much boost.
Old Mar 18, 2013 | 12:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
What heads cam and intake were on it? Its very unlikely a 305 would go 11's on just 4 pounds unless in a rail car
Old Mar 18, 2013 | 01:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
Stock heads and cam, 1le optioned 5 speed car, only mods were headers, full slp exhaust, roller rockers, bigger injectors. Car ran 11.90. This was with a Paxton supercharger not a turbo
Old Mar 18, 2013 | 01:35 PM
ninetyone's Avatar
Axle/Gears: 3:42
You have to realize that with forced induction, your adding well over 100 hp to a already v8 engine. What do you expect
Old Mar 18, 2013 | 01:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Sorry i dont believe it. You would need atleast 330 whp in a light car well driven to touch 11.9's and since a stock 305 with exhaust would only dyno 200-230 whp, you are saying each pound of boost makes 25-32.5 hp. That just doesnt seem likely on a tpi based stock head car. I would have to see that one to believe it.
Old Mar 18, 2013 | 01:47 PM
ninetyone's Avatar
Axle/Gears: 3:42
You can't go by numbers it does not work that way. Yeah he had problems on this site too with the classic response of " I don't believe you". This car was embarrassing c5 vettes at the time(year 2000). So you believe that low 14s are possible in a bolt on lb9 car but you don't believe that a supercharger could put one into the low 12's? And touching the 11's? I beg to differ
Old Mar 18, 2013 | 01:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Not on 4 psi
Old Mar 18, 2013 | 01:57 PM
ninetyone's Avatar
Axle/Gears: 3:42
Not on 4 psi
I'm almost positive it was 4 psi man, anyways , yes you are right it does matter how its set up too. You need enough fuel to keep detonation down. I think the op may have been wondering if the stock internals could handle a lot boost?
Old Mar 18, 2013 | 02:04 PM
ninetyone's Avatar
Axle/Gears: 3:42
My bad , he just texted me back. It was 8 psi. He started off with only 4 psi when he first installed the thing
Old Mar 18, 2013 | 08:34 PM
kad5118's Avatar
Car: 91 gta ws6
on all stock parts
Old Mar 18, 2013 | 11:39 PM
ninetyone's Avatar
Axle/Gears: 3:42
Originally Posted by kad5118
on all stock parts
Yes, and I am not sure if 1LE models had different pistons,crank or other bottom end parts than a regular Lb9 305.
Old Mar 18, 2013 | 11:47 PM
kad5118's Avatar
Car: 91 gta ws6
Ok than i should be ok then .I recently had the heads rebuilt and added 1.6 full roller rocker arms along with a very good tune up and waterpump replace.i just want about 360 at the rear wheel.I know that stock trans is good up too 400 pounds of torque i believe but i could be wrong.
$750 L98
Feb 1, 2025 02:25 PM
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
