What does anybody think of these heads for stock l98 with cam
Old 12-12-2017, 05:14 PM
amfornal's Avatar
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
Chevy SBC 350 200cc 64cc Straight Bare Aluminum Cylinder HeadChevy SBC 350 200cc 64cc Straight Bare Aluminum Cylinder Head
Part Number:PH-SB350-200-64SPart Type:Cylinder HeadsCylinder Head Style:BareCylinder Head Material:AluminumCylinder Head Finish:NaturalCombustion Chamber Volume (cc):64 ccCNC-Machined Combustion Chamber:NoIntake Runner Volume (cc):200 ccExhaust Runner Volume (cc):n/aCNC-Machined Intake Runner:NoCNC-Machined Exhaust Runner:NoIntake Port Shape:SquareIntake Port Location:StandardExhaust Port Shape:SquareExhaust Port Location:StandardSpark Plug Style:StraightComp. Valve Job:NoIntake Valves Included:NoIntake Valve Diameter (in):2.020 in.Exhaust Valves Included:No Exhaust Valve Diameter (in):1.600 in. Valve Springs Included:No Damper Spring Included:No Retainers Included:No Locks Included:No Valve Stem Seals Included:No Rocker Arm Studs Included:No Rocker Arms Included:No Rocker Arm Nuts Included:No Guideplates Included:No Valve Cover Mounting Style:Center & Perimeter BoltAccessory Bolt Holes Drilled:Yes Intake Valve Angle:23 deg.Exhaust Valve Angle:23 deg.Valve Guides Included:Yes Valve Guide Material:Bronze Valve Seats Machined:YesValve Seat Machine Style:3-angleValve Seat Material:Ductile iron Steam Holes Drilled:NoOiling Style:Through pushrod Quantity:Sold individually.
Old 12-12-2017, 05:15 PM
amfornal's Avatar
Engine: 5.7
Re: What does anybody think of these heads for stock l98 with cam
They are actualy 195 cc not 200 cc.
Old 12-12-2017, 05:17 PM
amfornal's Avatar
Engine: 5.7
I HAVE THIS CAM LISTED BELOW.
Anyone running Comp Cams 08-501-8 in L98? I have this cam in my 1989 L98 IROC-Z. Right now I am running this cam with ported intake and Magnaflow Dual Cat-back exhaust. This cam really woke up my stock L98. My question is what other Mods can I do that will get me the best bang for the buck. I would like to go with new heads, headers etc. but I don't know what the limitations of the Cam I already have put in are. Anyone have any suggestions on heads, rocker arms or anything else to get some more HP?
Comp Cams 08-501-8
Basic Operating RPM Range: 1,200-5,200
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 264
Advertised Exhaust Duration: 269
Advertised Duration: 264 int./269 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.495 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.495 exh.
Lobe Separation (degrees): 112
Old 12-12-2017, 08:42 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
Those heads are too big. Especially for a TPI which favors efficiency over size. I have a 383 with an insanely ported TPI, and I'm only running 180cc. A purpose built 350, with every part hand picked to rev high and flow, could use those heads. A good ole street 350, especially a TPI?? Too big. I wouldn't look bigger than 180cc unless you know exactly HOW and WHY you're gonna build that motor.
As for mods, exhaust should be a given, as well as some tuning. Also, look into a gear change and a torque converter. That'll do more than the cam did.
As for heads/HP...what are your goals? How often do you drive the car? How much can you do yourself? What's your budget?
Old 12-12-2017, 08:47 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
That cam you chose is pretty similar to the zz4 cam I was running. I had a mildly ported TPI, full exhaust, tuning, a 3.27 gear and a 2200 stall and the car was an absolute blast. Not modern day LS/Coyote fast, but still pretty fun.
Old 12-12-2017, 09:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
I had the next size up cam from that in a stock rebuilt L98. Ran good. Pretty good idle and made ok power. Stock heads and intake kill potential.
Who makes those heads? The ph-sbc350 part number makes me think proheader but not sure. If proheader they are decent castings. I'd get them bare and have a shop install valves and good springs for the cam
Ultimately you NEED an intake upgrade to see any real gains. Cam and heads on stock intake wont do a whole lot for the money. It will pick up but alot left on table
Old 12-12-2017, 09:26 PM
amfornal's Avatar
Engine: 5.7
l drive to car shows and on weekends. Looking for 300 to 400 hp TRYING to stay budget friendly.. I just saw these heads for like 300 dollars a pair and thought may be good deal. I did just order some headers. I am now debating on having stock heads redone or buy new ones. Car starting to burn oil bad @ start up.
Old 12-12-2017, 09:30 PM
amfornal's Avatar
Engine: 5.7
I just got these headers orderd. I thought they were ok for $115.Chevy SBC 350 1982 - 1992 Camaro Firebird Stainless Steel Exhaust Headers
Brand:Procomp ElectronicsPart Number:PCE316.1017Part Type:HeadersHeader Style:Performance Mid LengthHeader Material:Stainless SteelHeader Finish:NaturalWeld-Up:NoPrimary Tube Diameter (in):1 5/8 in.Collector Attachment:Bolt OnCollector Diameter:2.5 in.Cylinder Head Port Shape:OvalTuned:NoPrimary Tube Gauge:16 GaugeFlange Style:Standard OEMFlange Thickness (in):3/8 in.Bolts/Studs Included:NoGaskets Included:NoReducers Included:NoY-Pipe Included:NoMotor Mounts Included:NoTransmission Mount Included:NoQuantity:Sold as a Set
Old 12-13-2017, 07:36 AM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Ya know....I know it's not always a popular option, but I'm a huge fan of running vortec heads on a 350 TPI motor. You can find heads used on the cheap, and with a little work, they'll handle that cam no problem. There's a vortec TPI manifold in the classifieds right now too. Not gonna make insane dyno numbers, but it'll make one heck of a torquey street motor. Their power under the curve is a perfect compliment to a bolt on TPI motor.
spudz
11-19-2011 06:23 AM
Z28XTC
12-26-2008 06:59 AM
heavrolet9894
07-24-2007 09:53 PM
Little GTA
05-21-2002 03:41 PM
BranT
11-11-2000 11:39 AM
Quick Reply: What does anybody think of these heads for stock l98 with cam
