Code 42 and 33
Old Feb 9, 2018 | 06:14 PM
jsweatt's Avatar
Car: 1992 Camaro Z-28
Engine: 355
Transmission: Custom 700-R4
Axle/Gears: Stock 4th gen
Code 42 and 33
Hey guys. I'm at my wits end. So, the ignition module failed a while back. I had to replace the whole distributor because the wiring was corroded to the ignition module. I replaced the distributor and had the car running but I knew it wasn't timed properly. It took some time but I got my tools back from a friend and started checking the timing. During this process the fuel pump failed. Replaced the fuel pump and now I can continue with the ignition.
I have checked the timing over and over. I went so far as to put a compression gauge on the #1 cylinder to verify I was at TDC. The rotor is pointing to the appropriate plug on the cap. I can verify that I am close to time....about 5-10 advanced, but I notice some jumping.
The car still won't start. It tries and stumbles, but it won't run for any longer than a second or two. I checked the codes and I have 42 and 33. Is this a problem with the new ignition module?? Does anyone have an idea where to look first?
1992 L98 355 TPI
Stock ECM with custom prom
Thanks,
Jamie
Old Feb 9, 2018 | 06:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 42 and 33
Have you tried flooring it while cranking. This puts the ecm in clear flood mode Incase it’s flooded.
Sounds like you got the distributor installed correctly.
Have you gone back and verified fuel pressure after the pump install ?
Is this in your profile 92 tpi speed density ?
Old Feb 9, 2018 | 06:20 PM
jsweatt's Avatar
Engine: 355
Re: Code 42 and 33
I haven't tried flooring it. But yes, fuel pressure is there. I have a permanent gauge installed.
Old Feb 9, 2018 | 06:21 PM
Engine: Lb9
Transmission: M20
Re: Code 42 and 33
What about checking injector pulse with a noid light ?
You might have leaking injectors and a vats issue. Just guessing.
Old Feb 9, 2018 | 06:23 PM
jsweatt's Avatar
Engine: 355
Re: Code 42 and 33
Tried the flooring it bit, it started more than it has ever started. Runs terrible likes it's missing on a bunch of cylinders. I'm not sure what this means though..
Any more help is greatly appreciated.
Old Feb 9, 2018 | 06:40 PM
Engine: Lb9
Transmission: M20
Re: Code 42 and 33
Sounds like it was really flooded, it might be worth replacing the spark plugs then continue to diagnose.
Old Feb 9, 2018 | 06:56 PM
Engine: Lb9
Transmission: M20
Re: Code 42 and 33
You might want to disconnect the battery for 10 min or so to clear the codes
http://www.chevythunder.com/map_code_33.htm
http://www.chevythunder.com/est_code_42.htm
Old Feb 16, 2018 | 06:51 PM
jsweatt's Avatar
Engine: 355
Re: Code 42 and 33
Hi Tuned,
I replaced the plugs and it will start, but there is still an issue. It won't idle without holding the accelerator open a little. I can put it in gear and it doesn't miss like a cylinder misfire, it just randomly misfires and the tach jumps when this occurs (My tech II confirms this random change in RPM). What is the IAC reading supposed to be at idle? Mine is saying 160 with a learned value of 58. Maybe a stuck IAC? But that doesn't explain the random misfire and jumping RPM
Thanks again
Old Feb 16, 2018 | 07:55 PM
Engine: Lb9
Transmission: M20
Re: Code 42 and 33
The iac should be around 20 engine warm. The iac stuck open should cause a high idle. Do you still have the code 33 ?
Old Feb 17, 2018 | 08:59 AM
jsweatt's Avatar
Engine: 355
Re: Code 42 and 33
I didn't check for the code 33. The first step in the link you posted says to fix any rough idle first. I still haven't been able to fine tune the timing because it won't idle.
I'm thinking the IAC is stuck closed. It will stay running as long as I keep the throttle partially open. I found ACDelco 217-415 on Amazon, but that's an $80 guess. Do you know of any way to confirm it's stuck closed?
Thanks.
Old Feb 18, 2018 | 02:14 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Code 42 and 33
Do this, it starts at about 19:24
If the IAC isnt moving much like his doesnt then throw it away
sqzbox
Sep 28, 2003 10:03 PM
KED85
Feb 13, 2002 10:07 AM
Jax86SC
Jul 2, 2001 10:17 PM
Christos
Nov 17, 2000 05:23 PM
