will 1st gen 12 bolt work on 3rd gen without much mods?
Old Oct 7, 2002 | 08:19 PM
89maro400/700hp's Avatar
hey im lookin into rear ends and i was wandering if i could bolt up a 1st generation 12 bolt on my 89 camaro with little or no mods to do it.
Old Oct 7, 2002 | 08:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Welcome to thirdgen.org
Yes and no. It's close enough to the same width that it will fit fine however a first gen diff used leaf springs. Third gen is coil springs with a torque arm. You can convert the spring, shock and lower control arm mounts over but there's no way to attach a torque arm onto a factory 12 bolt diff. You could convert the rear suspension to ladder bars or 4-link but then that doesn't become a "little or no mods"
Old Oct 7, 2002 | 09:08 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
mmight as well warm up the welder now.
Old Oct 8, 2002 | 05:09 AM
thanks guys what about a ford 9 inch how bad of mods will i have to do to make that work or what k9ind of rear end do you guys suggest i should get.
Old Oct 8, 2002 | 07:02 AM
AlkyIROC's Avatar
Car: 87 IROC L98
You need to do the same thing with the 9" however a torque arm mount bracket can be made or purchased from Currie or Moser. It can be welded to the steel housing. The 12 bolt has a cast iron housing. The hardest thing is to find a 9" diff narrow enough to fit under the third gen.
You can buy a complete aftermarket 12 bolt or 9" for around $2000. It will be a complete bolt-in and use all the third gen suspension parts.
Why do you need to change the diff? I ran a beefed up 10 bolt for a few years and only switched to a 9" when I added a transbrake to the tranny.
Old Oct 8, 2002 | 02:21 PM
you think i could beat the crap out of a 700 hp motor with a beefed up 10 bolt
Old Oct 8, 2002 | 09:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If you have a 700hp engine, why are you even considering a junkyard diff that won't fit without a lot of modifications?
Old Oct 9, 2002 | 05:04 AM
i never said junk yard diff i said first gen 12 bolt. I was gonna put 373 us gears,eaton posi, and moser racing axles in the 12 bolt if it wasnt a big prodject to get it to bolt up
Old Oct 9, 2002 | 06:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is no other stock rear that will bolt into these cars.
If you want a 12-bolt, a few companies (Moser, Currie, KTRE, maybe Strange) make their own 12-bolt housings specifically for these cars; then you can use any 12-bolt carrier or gears you want.
But you won't find one laying around that will just go in with little mods; there's no provision for the torque arm in the other cars that came with 12-bolts. The suspension is completely different.
Old Oct 9, 2002 | 12:36 PM
chacane67's Avatar
USGear/Strang is the producer of the torque arm style center section, KTRE was the biggest purchaser of the diff and Moser and Currie are on the back burner.
I have installed quite a few of the Strange units, but I would go through it before the actual install (I have found some discrepencies). But its a solid unit after you take care of some little things!
Old Oct 9, 2002 | 02:00 PM
thanks man
Old Oct 10, 2002 | 05:16 PM
AFast83z28's Avatar
rear end
I am fixing to do the same thing. switch them out. I will probably use a 4th gen rear end though since they are a little more beefed up. the 98+s up camaro ss/trans ams have 31 spline axles i think...what would these hold to and what could do to make them last ?
I dont' have 2000 laying around or i would buy a rear end
Old Oct 10, 2002 | 05:24 PM
chacane67's Avatar
4th Gen beefed up?....its still a 7.5".... nothing different. The axles have never been its weak point.
Old Oct 10, 2002 | 05:44 PM
AFast83z28's Avatar
weak point
then what is the weak point of them?
Old Oct 10, 2002 | 06:25 PM
chacane67's Avatar
Its a 7.5", four-cylinder truck differential, that is under rated in your car when, your car is in stock form.
In short, it is way too small of a device (ring gear diameter) to really handle the power that we can create.
Old Oct 10, 2002 | 08:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Fourth gen diffs are not that much better. In the late 80's GM went from 7 1/2" ring gears to 7 5/8" ring gears. They all fit the same carrier and are still classified as 7.5" 10 bolts. In 1990 they upgraded from 26 spline to 28 spline. When the fourth gens came out in 1993 the diff was 2" wider on each side.
Fourth gen diff = 7.625" ring gear, 28 spline axles (weak factory ones), longer axles than a third gen (more prone to twisting). As much as the 10 bolt can be beefed up the weak link is still the tiny ring and pinion. I ran a beefed up 10 bolt for a year and ran 11.2's at 121 mph with no problems except for blowing up 2 engines in the process. After that year I added a transbrake and went right to a 9" since I didn't think the 10 bolt could take more than one hit off the transbrake.
Factory 12 bolt diffs are 30 spline. Factory 9" diffs are 28 or 31 spline. I run 31 spline Strange axles.
The $2000 package is for a complete diff. You can save money by just ordering the housing with axles then add in your own center section with carrier and gears. You can pick up a 9" housing with axles for about $900. Add the center section that can be picked up locally or at a swap meet and it's ready to go. Just make sure you order the axles with the spline count of the carrier you want to use. Going to 35 or 40 spline axles means an expensive carrier.
Old Oct 11, 2002 | 09:02 AM
NTChrist's Avatar
Stephen: So, would it be logical to assume that with an aftermarket ring and pinion, (from a good name) and a few misc details like a stud girdle, that a 10 bolt could withstand a litte hp?
All the accounts I've heard, you need a lot more than just a good ring and pinion. All hearsay, of course, as I've never pounded on a modified 10 bolt.
Back to the point, you have pounded on one, and could you divulge the recipe for your specific 10 bolt?
P.S., just checked out your website, nice car. I'm partial to the rough and tumble, thump the pretty-boy look myself. I'm not too sure about a car that runs high 10's with lexan t-tops, a 460 cubes, plexiglas windows, and a transbrake, tho... No disrespect intended (your car is, after all, a whole lot faster than mine), but do you think that there's a little potential left in your setup?
Old Oct 11, 2002 | 06:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The best thing would be to find some pro gears but since the 7.5" isn't a performance diff I doubt they make pro gears for the 7.5", Mine were Motive gears.
http://www.ws6transam.org/10bolt.html
Fancy paint and lots of chrome doesn't make it go any faster.
I've never had any problems with the T-tops and many cars quicker than 11.00 have plexiglass or Lexan windows with transbrakes.
There's isn't much left in the car to go quicker without spending a lot more money. I've already invested in a TH400 transbrake so upgrading to a powerglide tranny with transbrake is a huge cost. I'm trying to get the car down to around 2800 pounds, race ready but trying to remove 400 more pounds isn't easy. Aluminum heads, fiberglass door and fenders would help but again it's the cost factor. I could backhalf the car and tub it out for larger tires but again it's the cost factor.
It all boils down to money. If I want to go much faster the easiest way would be to drop in a 540 engine that has to run on alcohol.
With the few changes I'll do over the winter I'm hoping for a 10 second pass next year at altitude. Going to a lower elevation track shouldn't be a problem doing it. I could have had a 10 second pass in Yakima if I didn't float the valves.
Just remember that building a fast car isn't just about the engine. 500+ hp won't run 12's if the power doesn't get to the ground or the rest of the driveline breaks every time it runs. Everyone see magazine articles about "pro street" type of cars but don't realize that many of these cars would never go on a drag strip or that it costs so much to run and maintain them that they'll never be considered daily drivers.
Bracket racing is about 80% of all racing. Speed means nothing in a bracket race. Build a car that runs consistant and regardless of the speed, it will be hard to beat. Build what you can afford and upgrade to something stronger or better if parts start to fail.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
