T-56 install problem
Old Aug 31, 2003 | 05:30 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
Engine: 350 TPI w. Bolt_ons
Axle/Gears: Dana 44 3.73
Ok thank you to the guys that helped me out i am now done with the clutch master cylinder mounting and i got the 700r4 out as well as the driveshaft and the torque arm....My question here is this, i wasnt aware that i had to modify my torque arm to get it to mount unto the t-56. So i have to eaither cut an inch and a half off the arm and then weld it which i dont see being able to do or get a new torque arm....So will a torque arm off of a 97 camaro or any 4th gen camaro with a t-56 fit in my 3rd gen???
thanks
James
Old Aug 31, 2003 | 05:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
look for the tech artical on the t56 install, it goes in to very good detail with what is needed for the swap. the stock or factory t56 from 93-97 f-body cars should not need any cutting of the torque arm and drive shaft but, if you have the retro fit one then yes you need to cut&shorten the torque arm and driveshaft. I think spohn has a torque arm and mount for the retro fit t56 if that is what you have.
Old Sep 4, 2003 | 10:19 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
If you have a 4th gen t-56, use your stock t/a. I had a spohn in mine, but pulled it out due to too many vibration problems and clearance with the d/s loop. Just get a poly t/a mount.
Old Sep 4, 2003 | 12:04 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You need a 4thgen Torque arm poly mount and the stock tq arm will work fine!
Old Sep 5, 2003 | 01:02 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
My 3rdgen poly torque arm mount works fine. Actually the whole torque arm mount for the t-56 is the same part that the t-5's have. I ordered one for my t-56 then when it came I compared the two, its the same part so I returned it.
Old Sep 5, 2003 | 11:14 AM
IrocindatZ's Avatar
Car: 1989 IROC-Z
thats great but i didny have a t5 i had a 700r4
Old Sep 5, 2003 | 11:55 AM
Tony89GTA's Avatar
Car: 89 GTA
So did I at one time, I just threw that in there for the guys that are going from a t-5 and are missing there torque arm mount off the t-56. But my ES polly bushing did fit all three transmissions
Old Sep 5, 2003 | 12:01 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
700R4's are differernt. I thought they were the same and told the guy I bought it from to keep it. Later I had to convince him that I let him keep it to have him find me one. I'm glad I kept it after I installed the spohn T/A. (Which very well may be for sale now, I'm going back to stock for a while)
Old Sep 5, 2003 | 06:18 PM
Engine: ls1, LB9
graebz28, why are you going back to stock?
Old Sep 8, 2003 | 02:03 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
I don't need it, and I just want to see if it is causing any of the vibration issues. Once I run into traction problems I go back to it.
All I would like to suggest is to get a good driveshaft. I think that is my main problem after going to the M6.
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
cRoe4
Aug 7, 2015 08:46 PM
