after build up i blew everything!
Old Mar 13, 2004 | 05:47 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
hey guys i just got my tranny rebuilt and some custom work with a custom shift kit and a new 2200 stall. no more then 2 times getting on her i blew out the mounts so now i am trying to find the strongest mounts that can handle the power i am thinking of going for the steel ones but want to know if they are the strongest??
if there anything else i should change to handle hard launchs and shifts??
Old Mar 13, 2004 | 05:51 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
If you go with a solid tranny mount don't you also have to use solid motor mounts, then its alot harder on the rear end? I think you will also get more vibrations.
Old Mar 13, 2004 | 06:58 PM
ede's Avatar
ede
which mount, trans? buy a ES poly mount
Old Mar 13, 2004 | 10:27 PM
25THRSS's Avatar
Don't buy an es mount. Too many problems with with not fitting right and causing problems. Get a prothane one.
Old Mar 14, 2004 | 07:21 AM
ede's Avatar
ede
i've run ES mounts in every thirdgen i've had plus a few others i've worked on and never had a problem. care to expand a bit on what problems they cause?
Old Mar 14, 2004 | 07:54 PM
25THRSS's Avatar
https://www.thirdgen.org/techbb2/sho...spension+mount
Old Mar 14, 2004 | 08:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i use an ES mount on mine and I have no complaints either. Put one on my buddies car and no problems there either.
Old Mar 14, 2004 | 09:30 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Yeah, same here. I've put them on at least 4 different ThirdGens and have never had a single problem.
Old Mar 14, 2004 | 10:07 PM
Car: 1983 Z28
Transmission: TH350
these ES mounts, is that what they are called?? so i just go into a performance store and ask for ES tranny mounts??
are they sold at performance stores? or do i have to order them??
are they steel mounts? what are they??
one more thing what is the name of the mount in the back?? i am sure that mount went to, but i dont know the name to ask for it ?
thanks for the help!!!
Old Mar 15, 2004 | 11:46 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
The rubber mount under the tailshaft of the trans is the transmission mount. ES=energy suspension, it's a company. Their mount is made from polyurethane which is much stiffer than rubber. Summit sells them, though you may also find a local store that has them or can order them.
FormulasOnly
Jul 23, 2018 08:47 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
mud runner
Nov 2, 2015 07:30 PM
cking99
Sep 22, 2015 11:33 AM
