700r-4 Problem
Old Feb 6, 2005 | 06:39 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
700r-4 Problem
I RECENTLY HAD A REBUILD ON MY TRANNY LESS THAN A YEAR AGO. WITH OUT NOTICE I HAVE BEEN HAVING PROBLEMS. THE CAR ALWAYS SATY IN 1ST GEAR WETHER I TRY TO SHIFT MANUALLY IT DOESNT SHIFT. MAKES NO WEIRD NOISE WHAT SO EVER NO CLUES WHATS WROGN. ANY OPINION WHAT I CAN CHECK?
Old Feb 6, 2005 | 06:44 PM
fst2qtrmile's Avatar
Car: 1998 eclipse GSX
Engine: 4G63 2.0
Transmission: 5 speed
check your cable from throttlebody to transmission. kickdown cable. That cable opens certain valves at certain points of throttle position. I had to have mind adjusted - easily done with 2 people - and it shifted hard after i adjusted it.
Old Feb 6, 2005 | 06:54 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Also, pull out the governor and check it. If you are lucky the gear is stripped or broken. Cheap, easy fix.
Old Feb 6, 2005 | 06:58 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
im not to familiar to the governor i chcked the passin gear if it was loose but looks good.
Old Feb 6, 2005 | 07:03 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The gov is located on the dr side of trans behind a cover that is about 3 inches wide. The cover gets popped off with a large screwdriver and governor pulls right out for inspection.
Old Feb 6, 2005 | 09:34 PM
chris718's Avatar
if you install apressure gage on the 11mm tap above the linkage you can instantly nail down if its a governor or throttle valve /throttle valve circuit problem.hi line pressure at o tv cable pull is due to a stuck throttle valve or tv upshift valve.
Old Feb 7, 2005 | 04:41 AM
Pro Built Automatics's Avatar
This might be a governor problem (the weights are too light), if you cannot make a WOT shift on the 1-2 shift at the desired rpm. If you are trying to shift it manually before the WOT shift point of the governer, it will not happen. Let me know?
Old Feb 8, 2005 | 10:31 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
well i took it to the shop i got the tranny built he told me its a problem with adjustment and the governor. hopefullly it aint nothing big. so tmrw im goin to c whats going on
thankz
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
