700-R4 doesnt shift into 3rd gear
Old Feb 26, 2005 | 06:46 PM
Artem's Avatar
Car: Firebird Formula '91
Engine: 5,7 L
I'll try to describe the problem using my poor English:
If shifter in "D" then after start of movement it shifts to second, when its time to go up engine revvs but no third (like neutral).
When its in "2" then all the same, but if I move shifter in "D" third gear engages. But if I step more than half on gas pedal, then again engine revvs and no torque applied to wheels.
Rear gear is OK. Oil level and condition seems perfect.
Can you please help me to determine what goes wrong ?
On the day this problem started the car was idling for about 3 hours, may this be the cause ?
Thanks.
Old Feb 26, 2005 | 08:17 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Your transmission is kaput Time to have it rebuilt. Sounds like your 3-4 clutchpack is gone. Either that or its not creating enough pressure to execute the shift or hold 3rd gear. Either way you get to rebuild it. How hard is that going to be in Russia??? Are there many mechanics that are familiar with 700R4 transmissions????
Old Feb 27, 2005 | 02:19 AM
Artem's Avatar
Engine: 5,7 L
Unfortunately, its nearly impossible to find mechanic who can rebuild 700-R4 that lasts more than 20 000 Km
I have this table of pressures measured in idle and at 2000 RPM, made yesterday, May be this can help :
Gear Idle 2000 RPM
P 70 80
R 110 115
N 75 75
D 75 75
D 75 75
2 170 160
1 160 160
Readings are in PSI, with car raised on the lift.
Old Feb 27, 2005 | 07:29 AM
chris718's Avatar
you are missing the radings with the cable pulled outward,these are necessary in the diagnosis of the problem.the base pressures appear to be correct.the problem points to a 3/4 clutch malfunction in the form of loss or reduced clutch apply pressure or burnt or damaged friction elements.does the pressure drop on the gage during a 2/3 upshift?if so its an apply oil pressure problem,if it doesnt drop suspect burnt friction elements.
Old Feb 27, 2005 | 03:00 PM
Artem's Avatar
Engine: 5,7 L
Can you clarify which cable should be put outward ? Sorry, but I have no idea about how autotrannys works.
Old Feb 27, 2005 | 03:06 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
You want the detent or "TV" cable fully extended. This will apply maximum line pressure so you can see if you have enough pressure to make/hold the shift or if pressure is up then your 3-4 clutches are gone. HTH
Old Feb 27, 2005 | 03:33 PM
Artem's Avatar
Engine: 5,7 L
And also I need to measure pressure during upshifts ?
Old Feb 27, 2005 | 03:34 PM
Vader's Avatar
Artem,
Good luck wishes to you. I'd suggest getting a repair manual that includes transmission repair and diagnosis. You might as well add that to the shipment of the TCI (or whatever brand you choose) rebuild kit that you will have shipped to Mokbä. In that package, I would strongly recommend a TCI "Beast" reaction sun shell to replace the original.
Once you recieve all the parts and successfully repair the problems, YOU will be the American GM transmission specialist, and can possibly earn a few extra Rubles as a result.
http://www.tciauto.com/gm/gm_4L60E.htm#components
Old Feb 27, 2005 | 03:41 PM
Vader's Avatar
Lacking a manual for now, you can check this link to get an idea of what you'll be getting into:
http://www.route66wingsandwheels.com...88&view_pics=1
Old Feb 27, 2005 | 03:49 PM
Artem's Avatar
Engine: 5,7 L
Thanks, Vader. But our Moscow currency is US dollars, not Rubles, as you can think, even my salary is paid in dollars
I was thinking about purchasing the whole tranny, but shipment would run about 1000 $.
So, I'll probably try to rebuild it. To your opinion which brand should I use for rebuilding kit ? Engine now produces about 300 HP, but I plan to add another 100 soon.
Old Feb 27, 2005 | 06:17 PM
chris718's Avatar
we can set you up with the parts you need,as well as the technical information to get the job done right.we produce a package which includes our performance shift kit,servo , 2 boost valves and pr spring,3 accumulator pistons and 2 hd springs,hd band release spring,wide band,9 pack 3/4 clutch all steels and frictions,13 vane pump rotor with steel rings dual priming springs and vanes beast sun shell,all bushings ,washers, gaskets,filter,sealing rings and tech manual.for 349.00 us dollars
Old Feb 27, 2005 | 06:33 PM
Artem's Avatar
Engine: 5,7 L
I need everything, but the case. So I'll need valve body also and everything else, that I should put into case. What will shipping to Moscow run ?
Old Feb 27, 2005 | 06:41 PM
chris718's Avatar
IM TRYING TO EMAIL YOU BUT ITS NOT WORKING,CAN YOU SEND ME YOUR ADDRESSoops sorry for the caps.anyhow there is an area over boiling over with russian folk.brighton beach brooklyn,tough group of people to say the least.
Old Feb 27, 2005 | 07:17 PM
Artem's Avatar
Engine: 5,7 L
My e-mail is pff300 at mailsnare dot net, I sent you a letter.
Old Feb 28, 2005 | 09:21 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im thinking of rebuilding my trans also.
Thanks for the great link Vader. It has great pics, good details and tips.
jklein337
Sep 19, 2018 06:23 PM
suzuki949
Aug 28, 2015 08:07 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
