T-5 rebuild cost
Old 03-06-2005, 09:00 PM
czarjl's Avatar
Car: '82 Camaro Berlinetta
Engine: 305 Carb
Transmission: TH200
T-5 rebuild cost
I have ’92 RS with a T-5, I need to get the transmissions rebuild (don’t have time to do it my self). Any ideas what a decent price to pay would be and more importantly any one know a good place to take it in Western New York.
Old 03-07-2005, 06:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
About 2-3 times as much as a good used one will cost. Don't do it; just go to the junkyard and get another. Those things are a dime a dozen, they're everywhere.
What makes you think it needs to be rebuilt? It would rather suck if you did a bunch of transmission work and (for example) it still ground going into all the gears, or was stiff to shift when hot.
Old 03-07-2005, 07:52 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
FWIW, I grenaded a T5 here recently and (because there were few salvageable parts) had to buy a reman, it was $850, and I remember thinking I coulda put that money to a T56 or a Richmond, but I needed the car.
The funny part is the reman guy got the tranny core with the parts tie wrapped together.
Old 03-07-2005, 09:12 AM
czarjl's Avatar
Engine: 305 Carb
Transmission: TH200
The reason I think I need a rebuild is shifting is very hard, down shift is almost impossible (won’t go into gear and when I try to go into reverse I have always get a grinding sound (only time I get any kind of sound out of it) and have to slam the stick hard to get there. The clutch feels fine (when I put it to the floor it doesn’t feel like it is grabbing or anything) it’s just the shifting between gears that is an issue. The car has about 190,000 miles on it, previous owner rebuild the engine but I’m almost positive the transmission is original.
Old 03-07-2005, 09:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exactly why I asked....
The transmission isn't the problem. It's the clutch.
Replace the clutch. Leave the transmission alone. Don't forget to replace the pilot bearing, and put the throwuout on the fork correctly, and have the flywheel resurfaced.
Doesn't sound to me like there's anything at all wrong with the transmission.
Old 03-07-2005, 10:07 AM
Car: 83 Z28
What he said, except that I would replace the fork as well.
1. question now that we know it's the clutch, are the hydraulic cylinders working properly? Prior to digging into the bellhousing.
Old 03-07-2005, 10:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's always been like this ever since you've had the car, then it's entirely possible that the PO installed the throwout bearing incorrectly, as often happens.
The hydraulics don't just "go bad" and only work the clutch partially. They either work, or they don't; and virtually 100% of the time, the only way they fail, is that something bursts (either a cyl or the line). If nothing is burst, they're probably fine; and the problem lies with the clutch itself. So, verify that the end of the fork that the slave cyl pushes on, moves about 5/8" (that being approximately the spec); and if it does, then move on, and leave the hydraulics alone.
The main thing to avoid here, is the "shotgun" approach; the "maybe it's this, maybe it's that, I'll just replace the easy-to-get-to stuff" straight short road to automotive Hell. Instead, understand how the system works, and based on a logical analysis of the actual symptoms, identify the faulty part.
Let me repeat: THIS IS NOT A TRANSMISSION PROBLEM. There is nothing about a transmission that can produce the symptoms you describe. It is not possible for a transmission to do that to itself. IT IS A CLUTCH PROBLEM. The transmission is merely the victim: the problem lies elsewhere, but the symptoms appear at the transmission. For whatever reason, the engine is not being fully disengaged from the transmission when the clutch pedal is pushed. Either the clutch itself isn't working right (usually from incorrect assembly), or the pilot bearing is bad.
Old 03-10-2005, 09:45 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
if anyone want to get a rebuilt t-5 go to www.mantrans.com their out of tallahassee fl. i got mine for 650 plus 100 shipping for their unit to me and my core to them
Old 03-11-2005, 11:37 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
i rebuilt mine for 450.that was with the rebuild kit and third and cluster gears
Old 03-12-2005, 02:57 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Mine was rebuilt back around 97 or so. It was $450 and it included all new syncros and seals. 2nd gear was replaced also. The guy said it didn't look bad but was not mating up correctly so he put in a new one.
Old 03-13-2005, 03:12 PM
Car: 83 Z28
Mine came from mantrans and it was $850, that's in 2005 dollars.
Old 03-13-2005, 03:27 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
i just got mine last week for the above mentioned 650. the reason i went with route is that the idiot i bought the cat from a few months ago had put in a v6 t-5 ans ans-10 clutch. it also had the z-bar all out of whack so i just decided to go full pop and get a new t-5 for a v-8 and convert over to hydaulic clutch setup
Old 03-13-2005, 04:25 PM
Car: 83 Z28
Sounds like I'll be doing a little ***chewing
Old 03-13-2005, 08:44 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
note: shipping was $100 to and from for the core
Old 03-13-2005, 09:59 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
TKOPerformance rebuilds the WC T5 to handle 450 hp for under $1,000, plus shipping--but RB83L69 is wise in these matters. I'll send my '91 T5 to TKOPerformance one day for the upgrade and never run over 350 hp.--but I have a T56 in another car and the difference in feel is incredible.
Old 03-14-2005, 08:30 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
#rd gear ??????
So what would cause the trans not to be able to down shift from 4th to 3rd. Syncros?
Old 03-15-2005, 12:44 AM
Redliner's Avatar
Car: Tahoe
Clutch!!!!!!!! Yes!!!!!!!!!! Don't go overboard. I did. I spent 5grand on rebuilds, shipping, T56, and conversions. All I really needed was a 120 dollar clutch. I found out there are more reasons for using hydraulic clutches than being smooth. The hydraulic system is designed to make the clutch feel brand new till it disappears. I was using my back woods bayou common sense and all it did was cost me alot of money and eventually caused me to lose the Camaro
Old 03-15-2005, 09:46 PM
un4giv3n's Avatar
i have a similar problem. the gears are sometimes tight to shift in, like i'll have trouble shifting in to first once in a while, and 4th always grinds from neutral to 4th shift, but never grinds from 3rd to 4th.
i think it's the synchro, but a friend of mine had a similar problem (the tight shifting) when his clutch was bad.
the clutch does feel strong though, it doesnt slip at all.. even if i launch at 4-5k...
Old 03-15-2005, 11:57 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I had similar problems. it was the 3/4 syncros
i rebuilt my own. All new bearings and syncros Parts $150, busted 5th gear in removal process $150, experience priceless.
I think you have a syncro problem. The syncros match shaft speed between shifts. when they wear out, it will grind because the syncros are trying to ingage in the sliders at differnt speeds.
Old 03-16-2005, 08:28 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
My car always grinds 1st to 2nd... I just jam it in there
Everything that has to do with the clutch is new. It's gotta be my tranny!
But in your case, I had the same problem in my 84. Replaced the clutch (Luk, like $150) and all was well!
Old 03-16-2005, 08:53 AM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
How many of you guys complaining of issues are running gear oil in the t-5 instead of ATF or syncromesh? That was my problem. These trannies shifts like a$$ unless you got the right fluid in it.
Old 03-16-2005, 09:14 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
YES! AAMCO put gear oil in mine
I know the world class ones used ATF, but I think SOME of the others used gear oil. No idea what ones though.
Old 03-16-2005, 09:19 AM
supposedly it's 82-83 that are supposed to use gear oil. That's what my Haynes says anyway... I think with syncromesh you can't go wrong, I'm not sure about ATF (although I suspect they're very similar).
Old 03-16-2005, 07:52 PM
doc76239's Avatar
Engine: TPI 305
Heres some help
Hope this helps,
82-85 4speed 80w/90w gl-5 gear oil
86-87 4speed Dexron II auto fluid
82-84 5speed 80w/90w gl-5 oil
85-92 5speed Dexron II auto fluid
This is from a chilton manual .
Old 03-16-2005, 10:47 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
on my rebuilt t-5 from mantrans it had a tag that stated to use 5w-30 sythetic so i called and verified and was told to use reg.oil just sythetic
Old 03-17-2005, 07:37 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Did you drain it and put the correct fluid in? My T5 has a tag right on the case that says to use ATF only. Gear oil is not compatable with some of the friction materials used in the World Class T5.
Old 03-17-2005, 08:10 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
No, I did not, and the bearings went in it. They also had replaced my clutch, and didn't change the throwout bearing!! So I have a whining tranny and a cricket in my clutch.
Then when I went back for everything to be fixed under warranty, the guy had closed up shop and took off to Florida.
So yah, AAMCO sucks.
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
NZKnight
10-15-2015 02:47 PM
Damon
09-26-2015 04:29 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: T-5 rebuild cost
