trans go perfo shift kit
Old Dec 11, 2005 | 02:41 PM
snapsmagee2000's Avatar
Car: 91 z28 100kmiles
Transmission: 700r4 hoping to be t-5 soon
Axle/Gears: 3.42 posi
what do u guys and gals think of this shift kit
i want to install a shift kit that makes my car jump at every shift i was told that this one is a good one please let me know what u think
qty.
TRG-700 $139.69
Estimated Ship Date: Tomorrow
Application Show All
Brand: Transgo Performance
Product Line: TransGo Performance Shift Kits
Filter Included: No
Gaskets Included: Yes
Full Manual: No
Quantity: Sold as a kit.
Shift Kit, Performance, GM 700R4, Each
Check to make sure this part fits your application
Better shifts from the original shift-kit guys.
TransGo's Performance shift kits give you the hard-launching, tire-blazing shifts you want, after just a few hours' work with basic hand tools. TransGo even has kits for computer-controlled 4-speed automatics. Their performance shift kits can be installed with the transmission in the vehicle, and they come with complete instructions and a
Old Dec 11, 2005 | 03:52 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
if thats the one from summit racing, i have it installed now and i love it!!!!!
(if you end up geting this install with 3 washers, i did this and i chirp 2ed and get a little *** end wigle)
Old Dec 11, 2005 | 04:36 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
If you just want tire chirping shifts, you can go with the B&M kits. but if you also want to prevent common problems go for the transgo kit, which is more. i have both for sale for when you make your mind up, all wrapped up, for less than whatever you can find it for online. good luck.
Old Dec 11, 2005 | 05:52 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Go with the TRANS-GO shift kit. I have it and I LOVE IT!!! Chirp second gear everytime and on a good day i could get 3rd gear to chirp. I got mines through ebay. Also get the corvette servo too, that will also make a difference in your shifting.
Old Dec 11, 2005 | 06:55 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
do you use the stock shifter for this kit? or is it like the megashifter that brings the shifter.
Old Dec 11, 2005 | 07:02 PM
ZZ4 86 Z28's Avatar
shift kit is a set of springs and various other things like checkballs and valves that you install into your transmission. it has nothing to do with the shifter.
Old Dec 12, 2005 | 12:13 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Ramair21, how hard is the install of the corvette servo? Is it a reccomended mod or should it just be reserved for those more knowledgeable with automatic tranny's? Any answers to those questions would be appreciated.
Sorry if I jacked this thread. Go with the Transgo, much better than B&M. Iv'e rode(is that a word) in a truck with a transgo shift kit and it sure is great to feel that thing snap into gear.
Old Dec 12, 2005 | 10:45 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
The Servo wasnt hard at all. I hate dealing with trannys too. Just go ahead and do a search on google and on here. There is very helpfull tip on how to do it. The servo location is on the passenger side of the tranny. It looks like a circular cover. Check this site out, this is what i used.
http://www.impalassforum.com/tech/dr...nsgo_servo.htm
Trans-go is the way to go. Hope this helps.
Joey
Old Dec 12, 2005 | 10:53 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
this links seems alot better, check it out
http://sethirdgen.org/servo.htm
Old Dec 12, 2005 | 04:15 PM
ZZ4 86 Z28's Avatar
driven is the word you are looking for. and both the servo and transgo kit are fairly easy to install. and by the way, the transgo kit will work WITH the servo.
Old Dec 12, 2005 | 07:19 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Old Dec 12, 2005 | 09:45 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I bought the trans go shift kit from summit for my 87 GTA and HATED it. Don't get me worng I loved the tire chirps in second at W.O.T. but the part throttle shifts were VERY hard, down right hurt my neck everytime. Although I don't know the real reason but my trans only lasted 5000 miles, could have been the shift kit or could have been my trans was already on it's last leg or both. I have since replaced my trans with a newer 92 year unit and went to Dana at Pro-built http://www.700r4l60e.com/store/custo...&cat=28&page=1 and bought his street strip version and I absolutly love it. He takes the trans go kit and reworks it for better reliability and performance, also softenes the part throttle shifts so they are not so harsh. It has the tire chirps at W.O.T. and very smooth part throttle shifts. His may cost a bit more but it is well worth it, ( my neck thanks me for it to). Just my opnion though.
Old Dec 12, 2005 | 09:47 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
wow, thanks for the replies.
Old Dec 13, 2005 | 04:59 PM
ZZ4 86 Z28's Avatar
but with the transgo kit you can choose in 3 places if you want the shifts harder or softer. there are 2 springs to choose from in 2 sections and i think you can change the amount of washers in another place, or block off a certain part of the seperator plate or something. but i know its adjustable with the kit. usually trango is known for not just making it shift hard, thats what the B&M kit is known for.
Old Dec 13, 2005 | 05:44 PM
AaronIROCZ's Avatar
Yeah but in my situation that was 4 years ago and now they may have changed it since then, and it could have been just the way that I installed it, whatever it was I hated it. Dana at probuilt custom taylored it to my application and specifications, I told him what I wanted and he sent me a modified kit that changes the sizes of holes to drill and whatnot. I just did what he specified and it shifts great.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
