My T56 Swap Thread....
Old Mar 27, 2012 | 04:07 PM
  #401
midwest90rs's Avatar
Car: 1990 Camaro RS
Transmission: manual 5spd
Re: My T56 Swap Thread....
thanx
Old Mar 27, 2012 | 04:54 PM
  #402
87350IROC's Avatar
Car: 87' IROC
T-56 dust cover can be found here.
http://www.f2bkit.com/dust_cover.html
Old Mar 27, 2012 | 06:08 PM
  #403
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The Spohn piece is great if you want that giant monstrosity of a crossmember hanging down off the bottom of your car. Are there really no other options that leave the Spohn crossmember as the only real option?
Old Mar 27, 2012 | 09:29 PM
  #404
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
I couldn't agree more. I had one and took it off. I couldn't stand all the noise coming from the torque arm and the crossmember was always draging over the speed bumps and my car is not lowered.
Here is what I replaced it with and have been very happy. You have to run a factory torque arm though.
http://www.skulte.com/T56.html
Old Mar 27, 2012 | 09:33 PM
  #405
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
I think Hawks also has one that has double humps for clearance if you're running duals. I already got the spohn piece but I could see myself switching to the Hawks or SPD one.
Old Mar 28, 2012 | 10:12 AM
  #406
Car: 1992 Camaro RS
Unfortunately SPD doesnt make thirdgen stuff anymore. I got one of his last batches of crossmembers.
Old Mar 28, 2012 | 11:58 AM
  #407
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
In case anyone missed it this is what I did to my original clutch pedal to make it work with T56 Hydraulics. I hope it helps someone.
https://www.thirdgen.org/forums/tran...pedal-mod.html
Old Mar 28, 2012 | 12:24 PM
  #408
L695speed's Avatar
I suppose one could always modify (grind) the Spohn one down. But then it wouldn't look as nice. I'll have to see how it looks when my car is done. as of now, it doesn't look as if it will hang any lower than the exhaust. And I haven't had a problem driving it around here in NJ yet. (I had it running a couple years ago with factory setup)
Old Mar 28, 2012 | 12:26 PM
  #409
87350IROC's Avatar
Car: 87' IROC
The Spohn crossmemeber is easy to modify for more clearance. I cut down and reshaped the edge that hangs the lowest and probably gained a good 3/4" or so.
Old Mar 31, 2012 | 07:23 PM
  #410
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
I second this, good piece, I'm also using it. Can't use the T5 or 4th gen cross member, you need the conversion one.
Have either of you lowered your car? I have this on mine (just put in) and twice I have noticed what i think is it hitting the pavement at 70MPH in a dip in the road. I'm not 100% certain, the 1st time I thought it sounded like it hitting the ground, but the 2nd time it sounded like metal hitting metal. A big *** bang.
Anyone experience this? I wasn't able to put in the last two bolts as the holes were stripped so I only have the 1st 4 in, could that be it or could the tranny be hitting the undercarriage?
Old Mar 31, 2012 | 07:49 PM
  #411
L695speed's Avatar
There are only four bolts on the factory crossmember. I know there are holes for 6 but I didn't see why they were needed. I am lowering my car with a pro kit and have Konis on it, but I haven't driven mine yet. Hoping to before the year is out. Due to that I can't say if it will bottom out. I may take the grinder to mine to shorten it up anyway if I don't like how it looks relative to the ground. Just a thought but could your shocks be shot? If they are a car is more likely to bottom out. If they're in good shape or new then its possible its the crossmember. But based on what my exhaust was like before, I think its tighter to the body than my exhaust.
Old Mar 31, 2012 | 08:15 PM
  #412
88 TA GTA's Avatar
Do you think it would be as strong after grinding?
Old Mar 31, 2012 | 08:19 PM
  #413
88 TA GTA's Avatar
Thanks, the shocks haven't been replaced since I bought back in 2001, but I haven't put a lot of miles on, and when you push down several times it only bounces once or twice. I've been told if the car bounces more than 3 times you should replace, sound correct?
As for the six bolts, I don't think you would need them, but would prefer to have the two at the front and two at the back in instead of the 1st four bolt holes which are the furthest from where the T56 attaches to the cross member
Old Mar 31, 2012 | 08:31 PM
  #414
L695speed's Avatar
To quote 87350IROC "The Spohn crossmemeber is easy to modify for more clearance. I cut down and reshaped the edge that hangs the lowest and probably gained a good 3/4" or so." I guess it will be. I would see what others have to say since they've likely driven theirs on the street.
Old Mar 31, 2012 | 08:40 PM
  #415
87350IROC's Avatar
Car: 87' IROC
Have you guys taken a look at the OEM cross member next to the Spohn. The Spohn one is so overbuilt its not even funny. The material removed will not cause any issues.
And by the way I would highly recommend using all 6 bolts. The t-56 cross member hangs so far back, there is a big moment arm.
Old Mar 31, 2012 | 08:46 PM
  #416
L695speed's Avatar
Now that I think about it you have a good point in comparison to the OEM one. I won't worry about the material being taken off. Also I'll take your advice on the using 6 bolts. I will have to see if I can even get bolts started in the forward two holes. Next time I have it in the air I will check it out. I have a door I'm putting on the car to replace my rotted original. I'd rather on it on the ground for that.
Old Mar 31, 2012 | 10:36 PM
  #417
87350IROC's Avatar
Car: 87' IROC
The last two holes are not tapped. In my case the hole that was there was slightly to big to tap to 3/8-16 like the other trans mount holes. So I drilled and tapped larger and installed a heli-coil. 10 minute job.
Old Mar 31, 2012 | 10:59 PM
  #418
88 TA GTA's Avatar
Thanks, I thought the last two holes were stripped on my ride. I will use a tap set to fix.
Are you guys comparing to and original T56 cross member or the T5? Mine had an auto.
Old Mar 31, 2012 | 11:33 PM
  #419
87350IROC's Avatar
Car: 87' IROC
Mine was an auto as well. I think the crossmember is the same for the T5 and 700r4 though.
Old Apr 1, 2012 | 01:49 PM
  #420
88 TA GTA's Avatar
Thanks guys
Can anyone that has modified Spohn crossmember for more clearance post some pics?
I'm not sure I want to grind this down for 3/4 of an inch, when I'm not certain this is what is making the loud banging noise. I will mark it with chalk and check after it happens again. This way I will be able to confirm the Spohn is the issue.
Old Apr 1, 2012 | 08:07 PM
  #421
88 TA GTA's Avatar
I found this place a while back and contacted them. They told me it wouldn't work with and older block (2 PC RMS) and to find a T5 cover and modify it. I still can't see what the block would have to do with the T56 cover.
Old Apr 1, 2012 | 08:13 PM
  #422
87350IROC's Avatar
Car: 87' IROC
Don't know. I have a 1pc rms block and it works fine.
Old Apr 1, 2012 | 08:52 PM
  #423
88 TA GTA's Avatar
Thanks hopefully others will chime in.....
Old Apr 2, 2012 | 05:10 AM
  #424
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
wouldnt a 2" shift plate relocator work? and to use 3rd gen pedals and have them feel normal do you need to change anything? having a stiff clutch would throw me off..
Old Apr 2, 2012 | 05:16 AM
  #425
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Thats for the springs if im not mistaken.
Old Apr 15, 2012 | 10:17 PM
  #426
Car: 1992 Camaro RS
Just one last post on my cavalier slave cylinder. It apparently wasnt bled all the way, as it's firmed up quite a bit. It's still a soft pedal, but I can tell my foot is on it. May have just gotten used to it. I was gonna chagne it but I've grown to like it after all. It'll stay in the car. It feels "factory" now.
Old Apr 15, 2012 | 10:32 PM
  #427
L695speed's Avatar
Good to know, I'll have to refer to you when I eventually bleed mine. I'll probably like it as well.
Old Apr 18, 2012 | 11:40 AM
  #428
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Originally Posted by online170
Hey folks, been waiting a LONG time now to post these pix. Just a couple more things to do till im done. SPECIAL THANKS TO SOFAKINGDOM, for recommending the two jack method. DEFINATELY the easiest and safest way to go without a transmission jack. Just make sure atleast one of the jacks has a large cup, like VBMike mentioned earilier.
KCobra, its probably the same amount of work for going from T5-T56 or 700-T56, only change is, with auto you have to cut the firewall holes, and the shifter hole. In manual, you just have to cut the shifter hole.
Anyways. I didnt get to the tranny yesterday, cuz after 8 hours of differential equations, derivatives, C++ programming, and stress analysis, i was a little toast to work on the car.
The REALLY annoying part was though, today it just kinda slid in. I didnt even need any help, like there was never a problem. I had to jiggle a bit to get the dowel pins to go in, but other than that it was smooth.
I tried a bit of a different approach, instead of concentrating on putting the shaft in straight, i was concentrating on lining up the tranny to bell housing bolts. After i got that, i looked through the middle of the slave cylinder mounting studs, and tried to get theh inputshaft parallel, to match the tranny to engine angle. Worked pretty good.
Heres my older bro, putting on a couple bolts to hold the tranny in place.
Heres a close up of the dowel pins, JUST started on, and we tightened it on with the bolts after that. Since we can see this, im gonna use this to say, the fork was kinda tricky to put on. I just pushed it in, but its really a guess if its in the correct spot becasue you cant see anything. I pulled the end i could see, and slid it on, so the other end was closest to the clutch. This ensured it made it onto the throwout bearing. When the slave was mounted, the fork sat flush with the bell housing.
Heres the slave cylinder mounted. I found the hose is VERY VERY EXACTLY JUST the right size. No give or slack in it, i was afraid to break it.
FInally, this is what i was saying earlier. When i cut the hole, i just measured from the bell housing BACK, drilled ONE hole. and use that to cut the square. Problem with that is, when youre under the car, you dont know what STRAIGHT back is. As you can see i drilled the hole, too close to the left. (the transmission isnt fully raised so i can fix it a bit). No matter, i cut as little as possible, so i can just enlarge the hole to fit.
I thank you for this picture. Based on that alone I got my shifter hole spot on. I even had to trim it every so slightly so it didn't rub against the rear of the shifter assembly.
I'll take a new pic of it today with the trans installed but here's the trans out.
Unlike you I decided to drill the spot welds out to remove the entire bracket instead of cutting it with a dremel. can't say I like either way. I plan to goop some body body seam glue on the drill holes that aren't covered.
Old Apr 18, 2012 | 12:19 PM
  #429
Car: 1992 Camaro RS
The way these things just drop themselves into place out of nowhere after anywhere between 5 minutes and 5 hours of incessant struggle never ceases to amaze me. It's always RIGHT before you give up... and they just slip right in.
And I've got a transmission jack! I cant imagine how awful it must be without one.
Old Apr 18, 2012 | 12:23 PM
  #430
Mine most definitely did not slip in. We got it up there, enough to start the bolts, but no amount of wiggling would get it to slide that last 1/2" in. The splines were lined up, bit was the pilot bearing being a brat.
Ended up slowly working my way around in a star pattern tightening the bolts till the trans sat flush against the bell housing.
I test drove it on the jack stands last night. Goes into all gears super easy. Clutch is a Centerforce dual friction w/stock PP. The pedal is like butter.
Needs a real road test, but I have to wire up the electrical first. Worked on the car from like 10AM to 10PM.
Old Apr 19, 2012 | 01:06 PM
  #431
Here's the trans installed. I got the hole pretty spot on. Only needed a little trim at the bottom so it didn't vibrate against the trans tunnel.
Old Apr 19, 2012 | 01:21 PM
  #432
LilSki's Avatar
Car: 85 Trans Am
I don't know if it is mentioned here anywhere but since you guys are showing trans tunnels I feel most are going from auto to T56. But for those going from factory T5 to T56 you do have to cut the floor a little bit towards the back to clear the trans. I hope it helps someone.
Old Apr 21, 2012 | 01:20 PM
  #433
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I know this is an old thread, but i have a question. I'm kind of confused with the whole part about modifying the master cylinder rod. The pedals, trans, and master/slave cylinder assembly i have are out of a 94 camaro. I plan on using a stock clutch assembly, so do I need to modify the master cylinder rod, or will the rod travel be correct for a factory set up. I know you mentioned something about a high performance clutch, but the one i'm using is stock. Does the aftermarket high perf clutch have a different amount of travel?
Old Apr 21, 2012 | 01:36 PM
  #434
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
Nope no need for mod with the 4th gen pedals. Gunna have to elongate the holes that the brake booster goes through on the firewall and that's pretty much it it's pretty simple.
Old Apr 21, 2012 | 07:41 PM
  #435
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
if your using the 3rd gen pedals you will need to modify the rod. The clutch will disengage very high. Shortening the rod takes care of that. I've been running mine like this for over 4 years now.
Old Apr 21, 2012 | 09:22 PM
  #436
It's more of a preference than a requirement. I've gotten used to the clutch pedal position already and it's only been 2 days.
Old Apr 21, 2012 | 09:35 PM
  #437
LilSki's Avatar
Car: 85 Trans Am
Without modification you can overextend the slave and push the clutch fork into the pressure plate in some applications.
Old Apr 21, 2012 | 09:38 PM
  #438
Well then I'm screwed because the master I have has a crimped rod assembly, meaning its impossible to cut and thread it for adjustability. I don't think it would hold together.
Old Apr 21, 2012 | 10:09 PM
  #439
LilSki's Avatar
Car: 85 Trans Am
You can modify the pedal to do the same job as shortening the rod.
Old Apr 22, 2012 | 02:07 PM
  #440
alloy's Avatar
Car: 87 IROC-Z28
The problem with my car was I had zero free play. I had no way to be sure my clutch was fully engaged. It was very easy to modify the rod and be sure I had full engagement.
Old Apr 22, 2012 | 10:39 PM
  #441
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
For those of you who are curious about how to resolve the speedometer issue after a swap, here is what i did:
It's an Autometer 5" programmable electric speedo. It accepts the signal directly from the t56 VSS. This is what it looks like in a stock Firebird gauge-pod/cluster.
I had to take the speedometer apart and hack up the back of the stock gauge-pod a little bit, but the end result looks pretty good i think.
Eventually I plan on replacing all the gauges so they match. Just didn't want to spend like a grand upfront doing so.
Attached Thumbnails My T56 Swap Thread....-speedo-2.jpg   My T56 Swap Thread....-speedo-3.jpg
Old Apr 22, 2012 | 10:44 PM
  #442
85z28kid's Avatar
Car: 85 iroc-z28
That looks really good!
When I did my swap I just installed a 4th gen dash and it solved everything lol
Old Apr 22, 2012 | 11:09 PM
  #443
L695speed's Avatar
Looks good. I went to Alloy (who is a couple posts above here) for the Mechanical Speedo conversion. I'm happy with the work, I just need an engine to try it out . And hello to another NJ third gen owner. I'm up in Sussex County, car is in the garage. May see it this summer on the streets if a few things go my way.
Old Apr 23, 2012 | 06:50 PM
  #444
LilSki's Avatar
Car: 85 Trans Am
I did the swap from 85 mechanical cluster to an 89 electronic unit. Requires repining the dash but it works great. And it is probably the cheapest option.
Old Apr 23, 2012 | 10:20 PM
  #445
oamhmad's Avatar
Car: 84 Trans AM
Did you have to get some sort of chip to convert the t56 VSS signal to something the 89 speedo could understand? I couldn't find any stock third gen 160 MPH electronic speedos.
Old Apr 23, 2012 | 11:44 PM
  #446
88 TA GTA's Avatar
Use the Dakota Digital SGI 5 to convert from the 87 and up Trans AM and I believe 90 Camaro electronic speedo. Our cars (with electronic, not cable driven) has a 4000 or 2000 pulse per mile. The T56 has a 17 pulse per mile VSS. The SGI 5 converts the 17 pulses to 4000 or 2000 depending on how you adjust it and what your car requires. I'm still trying to fine tune mine. I'm either 18 miles under or 50 miles over my actual speed. I have moved the sensitivity (#2) switch and think I need to move #4 Cal Range. Haven't had time to get back to this yet. These are not expensive, I picked up mine new for $79.
Old Apr 23, 2012 | 11:48 PM
  #447
Use the Dakota Digital SGI 5 to convert from the 87 and up Trans AM and I believe 90 Camaro electronic speedo. Our cars (with electronic, not cable driven) has a 4000 or 2000 pulse per mile. The T56 has a 17 pulse per mile VSS. The SGI 5 converts the 17 pulses to 4000 or 2000 depending on how you adjust it and what your car requires. I'm still trying to fine to mine. I'm either 18 miles under or 50 miles over my actual speed. I have moved the sensitivity (#2) switch and think I need to move #4 Cal Range. Haven't had time to get back to this yet.
93' T56's are 11ppr, 94+ are 17ppr.
PPR is pules per revolution as measured at the tailshaft.
the 2000, and 4000ppm is Pules Per Mile, a different measurement.
With an 11PPR from a 93' T56 you can run a stock electric speedo with no real mods. However, it will be off slightly. My speedo reads about 5mph high @ 70mph actual.
I'm doing a 4th gen dash swap later so I just sold my Dakota Digital box.
Old Apr 23, 2012 | 11:57 PM
  #448
88 TA GTA's Avatar
Thanks thirdgen89GTA!
Old Apr 24, 2012 | 12:45 AM
  #449
In some searching I did it looks like the VSS between the two is the exact same with the exception of the Reluctor ring. I'm not sure how hard it would be to tear one apart. But you could drop a 11ppr VSS into a 94 trans and vice versa from everything I've read.
As for the speedo bit? It gets less accurate as speed increases ofcourse because of the multiplier difference.
At 70mph, it may read 75mph indicated.
At 30mph it reads like 32.5mph or something small.
Old Apr 26, 2012 | 06:10 PM
  #450
Engine: SBC 350
That AutoMeter speedo looks good. I have the digital dash, though, so I'm probably going to have to get the Dakota Digital box. I've been driving with my speedo screwed up for a while now, because I swapped gears to 3.70s, and never did anything to correct the speedometer.
