Do aftermarket convertors cause more noise? Added noise after convertor install.
Old 05-12-2008, 06:37 AM
Dr G's Avatar
Hi guys,
I've recently installed a new Edge Racing Convertors 9.5inch "Street Edge" TC set to stall at 2800-3000rpm. It cured a vibration problem I was having and the car has responded really well to the higher stall.
The problem I'm having is since that very day of install there is a new noise my car is making. It is most noticeable when you hold the car in gear, as opposed to leaving it in drive. There is a 'wooing', almost whistling like sound that is louder with higher engine revs. The transmission fluid was changed and the level appears correct. This noise was definitely not there before the new TC was put in.
Any ideas what this could be? Do aftermarket convertors give additional/different sounds? Could there be an additional problem with the transmission itself?
All suggestions are welcome. Thanks!
Old 05-12-2008, 06:48 AM
squeeezer's Avatar
Car: 5 cars
Re: Do aftermarket convertors cause more noise? Added noise after convertor install.
is it the same when you put the shifter in od vs d or 2 and 1 for that matter??
Old 05-12-2008, 06:50 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
I believe I have that TC as well, or something very similar that has just been put into mine. I've noticed that same "wooing", unfortunately I've changed so many other things I couldn't pinpoint if it was this.
Be curious to see inputs from people that also have the Edge TC
Old 05-12-2008, 06:51 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
It should not make sound or noises.
Old 05-12-2008, 07:03 AM
Dr G's Avatar
Yes, the noise is still there in Drive, but is more noticeable in 1, 2, and 3.
The transmission does not slip at all either.
Old 05-12-2008, 09:05 AM
squeeezer's Avatar
Car: 5 cars
im asking cause of the pressures .............ie pump noise
Old 05-12-2008, 08:50 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i have an edge 9.5 3200. mine seems like you can hear the fans spinning as well. makes me curious, but i'm not too too worried.
my car makes so many stupid noises anyway, i just crank up the tunes lol.
Old 05-12-2008, 11:32 PM
EvilCartman's Avatar
Car: '82 Z28
Didn't notice any new noise coming from mine after putting in an Edge converter... exhaust is pretty loud though so might not be able to hear it.
Old 05-14-2008, 12:46 AM
Pro Built Automatics's Avatar
I have heard this several times from customers. I guess its normal for his 9.5" TC's
Old 05-16-2008, 02:37 PM
Dr G's Avatar
Dana, When I contacted the company directly they say it sounds like a power steering pump low on fluid. You sell these convertors I believe, from your website, have you found them durable enough? That is, do you think I should worry about this noise, or accept it as a 'characteristic' of the new TC?
Old 05-17-2008, 03:37 AM
It is just the noise, that I hear complaints on, otherwise the TC's seem to hold up ok.
gta892000
08-11-2019 11:16 AM
AmpleUnicorn88
09-24-2015 09:15 AM
Abubaca
Car Audio
09-24-2015 02:33 AM
Fronzizzle
09-08-2015 12:10 PM
Randomtask2
09-07-2015 05:06 PM
Quick Reply: Do aftermarket convertors cause more noise? Added noise after convertor install.
