T5 issue
Old Jun 9, 2008 | 05:35 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
T5 issue
89 firebird formula tpi T5... When i try to start the car with the clutch fully floored the car tries to take off like the clutch isnt even pressed. wut is causing this, and how do i fix it?
Old Jun 9, 2008 | 06:26 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: T5 issue
sounds like you have a blown clutch slave or master cylinder . good luck .
Old Jun 9, 2008 | 07:22 AM
Nater36's Avatar
Re: T5 issue
after its running it doesnt do that tho?
Old Jun 10, 2008 | 11:43 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: T5 issue
you may need to replace the pilot bushing(or bearing). When it is cold it will grab the input shaft like the clutch is still engaged, after warming up it will operate normally
Old Jun 11, 2008 | 02:16 AM
Nater36's Avatar
Re: T5 issue
well it has been sitting for 5 months... could that have anythying to do w/ it.. because all of that is reletavely new approximately 5k miles on new clutch kit...
Old Jun 11, 2008 | 05:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: T5 issue
Check the fluid level first, it could have a slow leak somewhere. If it is leaking, I would bet it's the slave cylinder.
Old Jun 12, 2008 | 12:09 AM
Nater36's Avatar
Re: T5 issue
alright, do I check that on the passengers side ?
Old Jun 12, 2008 | 08:29 AM
hudjoes's Avatar
Re: T5 issue
hey man yesterday i was having the same problem with the t-5. the clutch pedal was depressed to the floor but seemed that it wouldnt engage. so we put the car up on the jack stands and started in 1st gear, and then went through all five gears. some how that freed up the clutch up and we went rolling down the street.
Old Jun 12, 2008 | 02:08 PM
Nater36's Avatar
Re: T5 issue
alright, hopefully thats the case for me... wont know til its outta the shop tho.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
