Should i replace my clutch myself or...?
Old Aug 10, 2008 | 12:14 AM
xChAoSx's Avatar
Car: 1987 Firebird
asdasdasdasdasdasdasda
Old Aug 10, 2008 | 03:01 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Should i replace my clutch myself or...?
To replace the clutch on your car it wouldn't be to bad at all maybe a few hours of work, the T-5 is such a light tranny which makes things so much easier. If you don't have the tools though probably better take it to a shop plus your going to have to get the flywheel machined anyways. Just make sure they don't rip you off to much.
Old Aug 10, 2008 | 12:27 PM
xChAoSx's Avatar
Car: 1987 Firebird
aasdasdasdasdasdasdasd
Old Aug 10, 2008 | 12:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by xChAoSx
Well im going to call around and quote but if it too pricey ill do it myself. Ill borrow some tools from a friend. haha gotta get some heavy duty jack stands because our cars are heavy and low. plus 2 hours or so doesn't sound bad at all.
Took me two hours (maybe more) to remove that #$%#@ bolt at the top of the bell housing. The swap is generally straightforward. Some research here and a shop manual will probably save you time and money.
JamesC
Old Aug 29, 2008 | 01:10 AM
xChAoSx's Avatar
Car: 1987 Firebird
asdasdasdasdasdasda
Old Aug 29, 2008 | 02:42 PM
xChAoSx's Avatar
Car: 1987 Firebird
asdasdasdasdadasdadASDAS
Old Aug 29, 2008 | 04:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Shouldn't be too bad.
Buy the full clutch kit. Remember to have another car there, since you'll have to drive your old flywheel over to a shop to get it machined (that's probably the bulk of the reason why it shudders...). Might need to replace it if it's really gone bad.
I'd want friends over to help, the tranny is still pretty heavy...
Put it up as high in the air as you can, that's my point of advice....
I'd also recommend buying a poly tranny mount while you're there. Chances are good yours is shot, and it's a $20 part....
Your clutch kit should come with a throw out bearing... right?
Old Aug 29, 2008 | 05:32 PM
JamesC's Avatar
And remember a new pilot bearing.
JamesC
Old Aug 30, 2008 | 11:18 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASD
Old Aug 31, 2008 | 03:21 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASDASD
Old Aug 31, 2008 | 03:59 PM
JamesC's Avatar
Air tools are great (and a must have for an old fart like me), but you can complete the job with hand tools.
JamesC
Old Aug 31, 2008 | 04:15 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASDASDASDA
Old Sep 1, 2008 | 09:00 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
its not that bad, Your list seems pretty complete. The hardest part is going to be the pilot bearing, you might need a slide hammer to get that out. Ill give you a rundown how to yoke the trans.
1) take the console apart to remove the shifter.
2)Jack the car up and support it, then remove the driveshaft and I normally just take out the nut that holds the torque are clamshell mount togather.
3) Disconnect the speedocable or speed sensor, and reverse light switch, disconnect the slave cylinder. Youll save time by just unbolting it and letting it lay there, dont disconnect the line because youll have to bleed it later.
4) put a jack under the tailhousing, and take off the crossmember.
5) Lower the tranny until those top 2 bellhousing bolts get to be in sight. I normally use a 18inch extenstion. Before you do that, I normally take a rachet strap and wrap it around the tranny and jack just to stabilize it. Then it should come right out.
Look up a picture on how to replace the throw out bearing, I dont think its that hard, but I guess alot of people screw it up.
If it seems to hard, it only pays 5.5 hours according to alldata, so you know if your getting raped at a shop.
Your going to want to buy a torque wrench. The only bolts you really need to torque are the flywheel to crankshaft, and the pressure plate to flywheel bolts.
Old Sep 1, 2008 | 09:19 AM
JamesC's Avatar
Messy but, you can pack the bearing with grease and use an old alignment tool (or even a dowel rod) to drive the bearing out. I've even heard of threading a bolt into it working it out that way.
JamesC
Old Sep 7, 2008 | 09:07 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASDASDASDADSADS
Old Sep 8, 2008 | 06:07 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Do you need to break it in?
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
