Help needed to replace TV cable
Old Feb 9, 2001 | 07:15 PM
Cosmik Debris's Avatar
How on earth do you get at the transmission end of the TV cable? Can you drop the transmission down so that you can get in there or is there some other secret to it. I am presuming you can change the cable without dropping the trans pan.
Thanks for any insight.
Cosmik Debris
Old Feb 9, 2001 | 08:03 PM
Nitro Don's Avatar
You dont have to drop the tranny,but it would make it easier.Ive done it both ways.
There is a small bolt that holds the TV cable to the trans.Take the bolt out and pull the TV cable up.Remove that S hook from the cable,letting it go back in the trans.Then remove your TV cable.When you put the new cable on,pull the S hook up,slip it on the TV cable,put the bolt back in.
Hope this helps,m
Nitro Don
Old Feb 9, 2001 | 08:40 PM
Thanks, I can't see how I can get a spanner onto the bolt let alone hang onto or retrieve the s hook from the tranny. If I decide to drop the tranny how far down will it come if I take the rear mount off?
Cosmik Debris
Old Feb 10, 2001 | 05:19 AM
The ODB's Avatar
Several inches...
until your distributor cracks up against the firewall (depends on model year)
good luck
ODB
Old Feb 10, 2001 | 07:32 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I have replaced several TV cables with the tranny still fully bolted up in the car. The bolt is like a 10, or 8mm and I use a small boxed end wrench to break it free, then it usuually comes out by hand. Once you get the bolt out, pull up on the tv cable and you will understand about the "S hook". Its very easy. Don't forget to adjust it when you are done.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 10, 2001 | 12:22 PM
MrJ's Avatar
MrJ
GMTech, I have a question regarding this. How do you undo the little clip on the engine bay side of the TV cable? I mean the clip that attaches to the throttle butterflies.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Feb 10, 2001 | 05:44 PM
Well I finally did it. What a PITA. I must've been under my car for 10 hours. It was quite restful. Hooking the S shaped hook into the cable took most of the time. Definately helps to lower the tranny though.
Thanks Don.
Cosmik Debris
Old Feb 10, 2001 | 05:46 PM
<font face="Verdana, Arial" size="2">Originally posted by MrJ:
</font>
Slide it forward.
Cosmik Debris
Old Feb 10, 2001 | 06:08 PM
MrJ's Avatar
MrJ
That's not what I mean. Once the cable is off of the butterflies, that little clip on the end is still there. It's impossible to slide the cable out while that thing is on there. Know what I mean?
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
Old Feb 10, 2001 | 09:02 PM
82z's Avatar
82z
J are you talking about the plastic piece that attaches to the throttle lever. If so it is attached at the factory to the wire.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 10, 2001 | 11:46 PM
MrJ's Avatar
MrJ
hmmmm... so if it's attached at that end from the factory, then how can the cable be removed and installed? The cable sits inside a tube, and with that piece on there, it's gotta be too large to fit through that tube, right?
Old Feb 11, 2001 | 02:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TV cable and sleeve are replaced as an assembly, just like a shifter cable.
Old Feb 11, 2001 | 01:49 PM
MrJ's Avatar
MrJ
OK thanx.. I get it now.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
BBSDesigns
Aug 11, 2015 07:39 PM
Rustyweb7
Aug 9, 2015 03:05 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
