where does your car shift
Old May 15, 2001 | 09:11 PM
dwhess504's Avatar
I have been playing with my TV cable, and I can't get it to shift right. It now shifts real hard, but when I floor it it doesn't kick down and will **** at 3500 rpm. Where is my car supposed to shift at on WOT??
1988 Trans am GTA
stock, only mods:
flowmaster exaust.
in process of getting more
Old May 15, 2001 | 09:24 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Mine shifts at 4600 at WOT.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old May 15, 2001 | 10:01 PM
ne14lx's Avatar
you have got the cable set too tight the car should shift into drive at 38 to 40 mph."normal driving."you need to push your button and pull the head od the cable towards the front of the car a couple of teeth. when you push it back it tightens the cable leading to your problems.don't get on the car untill the cable is set right you will trash your tranny
Old May 16, 2001 | 02:53 AM
transfixleo's Avatar
It all depends on the calibratin of the tranny. My '88 Camaro shifts at 5500 RPM stock (it has a TransGo Shift Kit but that doesn't change WOT).To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all of the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal floored, press the D button and pull the cable back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does. If after this you don't have what you want then you have work to do inside of the tranny.
Old May 16, 2001 | 06:57 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
My tranny shifts at 6,000 rpm.
Adjusting the TV cable isn't the correct way to alter your shift points. Basically the TV cable should be pulled to the max at WOT assuming the correct geometry and thats the only setting it should be in.
Changing your shift points should be done by altering the governor weights and/or springs.
Old May 17, 2001 | 03:06 AM
jaretz28's Avatar
my animal 700-R4 will shift anywhere betwwen 6300 - 6600 RPM depending how it feels that day!
Old May 17, 2001 | 03:27 AM
What did you do to get those WOT shift points? It didn't come from the factory that way.
Old May 17, 2001 | 06:26 AM
Pro Built Automatics's Avatar
I agree with transfixleo on this. It did not come from the factory that way.
Old May 17, 2001 | 06:27 AM
JoelOl75's Avatar
I got a v6 governor and cut the springs a little.
Old May 17, 2001 | 07:48 AM
Mark W. Winning's Avatar
Center console...
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old May 17, 2001 | 09:30 AM
dwhess504's Avatar
Well.... Whats the factory shift point??
Old May 17, 2001 | 01:31 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
my trans is set to shift anywhere between 4500 and 5500 rpm. depends on how much i get on it.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
Old May 17, 2001 | 08:29 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
5300
Old May 18, 2001 | 03:47 AM
Hi JoelOl75,
Where does it shift at minimum throttle? Part throttle, just keeping up with traffic? Does it seem to hang onto a gear a little too long with this setup?
Old May 18, 2001 | 06:27 AM
JoelOl75's Avatar
No, the part throttle shifts seem in the right places. I know adjusting the TV to change your shift points also changes part throttle firmness, but I haven't had any problems so far by modding the governor... it feels the same after, just the wot shifts are later.
Old May 20, 2001 | 08:08 AM
dwhess504's Avatar
when I adjust my TV cable it shifts at 5300. After a couple days of driving it won't go past 4500 rpm at WOT so I can't shift?? WTF??? it sucks Is it the TPS??
1988 Trans am GTA
stock, only mods:
flowmaster exaust.
Old May 22, 2001 | 05:47 PM
It is possible that the cable is slipping. Did you use the factory method?
Old May 22, 2001 | 06:25 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
hrmm, i would like to say the cable is stretched. But i am no expert. my car shifts at 5,600.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 25, 2001 | 12:41 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I believe that you will find the factory LG4 transmissions shift at about 4000 RPM, whereas the L69's all shifted at 5000 RPMs and the TPI motors shifted somewhere in-between.
Of course, we all noodle around with our cars, so they now shift at many different speeds. Mine's currently shifting at 5900.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
Old May 28, 2001 | 06:30 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My 86 IROC (305 TPI) shifts at 5000 rpm.
Z's r Best
Old May 31, 2001 | 07:18 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
If I leave it in Drive my car shifts at like 4500 at WOT. Which really sucks cause thats pretty damn low.
Chris
91 RS 305 TBI
Eternal Rev
Old May 31, 2001 | 11:15 PM
Digger's Avatar
My TH-350 shifts at 4000 at WOT, it leaves a patch about 10 feet long.I have a 350.
Old Jun 3, 2001 | 07:01 PM
whiteroc's Avatar
My 89 IROC-Z 5.7L Shifts at 5200 RPM 1-2 Shift and 5600 RPM 2-3 Shift. If I leave the gear selector in 3rd the 1-2 shift is at 5600.
This is way too high an RPM for a stock TPI motor. When I last had it at the track I noticed that after 5100 RPM the engine does not want to climb anymore.(slowing down both E.T. and MPH) Between 4800 and 5000 RPM Shifts for stock Cam & Intake is the best shift point.
Needless to say I will be fixing the problem on mine very soon.
89 IROC-Z 5.7L
PERFORMANCE RESOURCE CHIP
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER
2.77 Gears
Best E.T. 14.37 @ 95 MPH
Best 60ft. 2.07
Trans shifts late
Old Jun 3, 2001 | 08:19 PM
dwhess504's Avatar
Whiteroc,
I feel the same way, how do you adjust the shift points to where you want them?
1988 Trans am GTA
stock, only mods:
flowmaster exaust.
Old Jun 3, 2001 | 10:31 PM
whiteroc's Avatar
The trans shift points are determined by the setting of the throttle valve cable in small part but will damage the trans if far off of the factory settings. The other way which is what you are basically asking for is the governor weights. The heavier the weight the sooner the trans will shift and the opposite effect for lighter weights. You would have to go into the side of the trans where there is a round cover (half way up the side of the trans)remove the cover, change the weights, drive the car to see if it shifts at the RPM you are looking for. It's basically a trial and error thing -at least thats what the guys at the trans shops have been telling me. Be carefull though, some shops don't have a clue about the governor weights and will tell you that you need to have the trans rebuilt to fix your problem. Hope this helped you some.
89 IROC-Z 5.7L
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER
2.77 Gears
Best 60ft. 2.07
Trans shifts late
Old Jun 3, 2001 | 10:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
4600 RPM's
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
