Weird kickdown problem with 700R4.
Old Jul 19, 2001 | 04:46 PM
irocbsa's Avatar
I've noticed as of late that when I'm on the interstate cruising at about 70 and put the pedal to the floor, the tranny shifts down to second and stays there. It will not shift out of second. The revs peg at 6500. I know the tranny is in gear because if I let off the gas the motor will slow the car down. If I let up to about 2/3 of full throttle then the tranny will go back into third and start pulling strong again. It does the same thing with the shifter in D and OD. Sometimes the tranny will rapidly shift between 2nd and 3rd when I put the pedal to the floor as if its hunting for a gear. The tranny does not do this when I take off from a start, although it will not manually shift into third at full throttle for some reason. I heard this is a common problem with the 700. Could these two be related, and what is going on. Its beginning to worry me.
Oh yeah, the TV cable has been adjusted properly and has been checked to make sure that it still is prperly adjusted.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 20, 2001 | 03:11 AM
irocbsa's Avatar
ttt
Old Jul 20, 2001 | 03:53 AM
86_Dan_Z28's Avatar
Car: 86 Z28
3-4 clutch pack is gone, time for a rebuild.
Old Jul 20, 2001 | 03:58 AM
transfixleo's Avatar
Ditto
Old Jul 20, 2001 | 03:31 PM
Pro Built Automatics's Avatar
Does the trans shift ok at 1/2-2/3 throttle when making the 2-3 shift? Let me know.
Old Jul 20, 2001 | 08:46 PM
irocbsa's Avatar
YES!!!!! If I only go to 1/2 to 2/3 throttle the tranny will shift fine. When it inappropriately downshifts to second on the interstate I can lift the pedal back up to 2/3 throttle and it will shift to third. But if I go back to full throttle then it will slam back to second again. Thanks for the help.
bsa
Old Jul 21, 2001 | 09:27 AM
You could have a couple of problems here. Assuming that at one time it worked ok, the oil that applys 3rd gear might not might not have enough oil to overcome the checkball capsule in the input drum. The checkball in the capsule (due to centrifugal force) will not seat itself if there is not enough volume of oil to push the ball on its seat when 3rd gear is trying to come on. This lack of enough oil is usually due to crossleaks that come with time. To fix this the easy way would be to install the Trans-Go Performance Shift kit along with the .471 or .500 main boost valve. This kit will TRIPLE the volume of oil to 3rd gear, and it will address other problems as well. The kit sells for $78.00, the .471 or .500 main boost valve $10.00, and if you manually shift the transmission then add the .296 intermediate/reverse boost valve $15.00.
This Should Help!!!
Old Jul 21, 2001 | 03:10 PM
irocbsa's Avatar
Thanks again. Did you say that the kit sells for $78?? I thought it listed for around 130??
bsa
Old Jul 22, 2001 | 07:22 AM
Don't you alrready have the TransGo Kit listed as in your tranny?
Old Jul 22, 2001 | 03:08 PM
irocbsa's Avatar
Ha, funny you should mention it. I had it on my previous tranny that blew out and forgot to remove it from my sig. The shop I had rebuild the tranny was supposed to put a transgo in there but I found out a few months later when I started getting unwanted shifts to overdrive that it wasn't the transgo. Boy was I pissed. They got a piece of my mind.
bsa
Old Jul 23, 2001 | 08:33 AM
This is, unfortunately not an uncommon problem. Often when a 'Shift Kit' is requested, the shop will charge more and then do a few 'tricks' to make it shift harder. Unfortunately this is NOT what a true Shift Kit is all about. You might consider sueing them though. I am sure that they laughed about it when you left.
Old Jul 23, 2001 | 11:48 AM
IROC5.7TPI's Avatar
I've been having the same problems. After much advise from TransFixLeo, I still have not been able to find a reputable shop to do the work for a decent price without wanting to @ssrape me and trying to fix something thats not broken.
I need to get mine fixed. Funny thing is...it only started doing this after a complete overhaul. I had it done at the trans shop I used to work at. The guys there were a little "old school" and I don't think they know a whole lot about anything newer than a T350.
Other than that, I have a real solid trans. It has firm shifts and the stall is right (I ordered the converter. Its a Dacco.)
So you guys are saying its in the valve body and not the governor?
Also, I have not WOT 4th gear like I used to???
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Cleotiz
Jan 6, 2018 08:56 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
