How strong is a Probuilt tranny???
Old Oct 8, 2001 | 09:18 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I'm looking for an automatic with overdrive but it needs to be strong. It will be backing a 427 twin turboed small block. I heard Probuilt was the best so I'll probably go with a tranny from them. Just wanted to know everyone's recommendations. Thanks.
Old Oct 9, 2001 | 06:25 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
His best is said to only hold around 650. A TT 427 is should be pumping awhole lot more. I think you might be in for a TH400 or powerglide
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 9, 2001 | 05:02 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
No no no, lol. This car will be driven (maybe even daily! )
, not just a racer. I want overdrive. It might not be a 427 though. It's definitely going to be an aluminum small block that's twin turboed. What's the strongest auto with OD?
[This message has been edited by soulbounder (edited October 09, 2001).]
Old Oct 9, 2001 | 06:31 PM
Jay 727's Avatar
Either a 4L80E or a built turbo 400 with a 34 element sprag and a gear vendors overdrive unit. If you can afford an aluminum big block I'm sure you can afford the gear vendors unit.
Old Oct 10, 2001 | 05:03 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Not big block. 427 Small block!
Old Oct 11, 2001 | 09:14 PM
Crosley4's Avatar
You want a 300M steel input shaft and a billet drive hub for the T400 behind the twin turbo small block.
2000 Silverado
2000 Impala LS
1985 Camaro V6
1971 Chevy truck ZZ4 power
1962 Ford Falcon
1961 Dodge Lancer 350 chevy power
1961 Morris Minor 1000
1961 BugEye Sprite
2-1951 Crosley wagons
1948 Crosley wagon
1947 Crosley Sedan
1947 Crosley Pick-up
1948 Simca
Old Oct 11, 2001 | 09:47 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Hey, thanks for the tip. I'll definitely be doing lots of research and calculations to make sure the tranny is beefed up.
Old Oct 11, 2001 | 11:00 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Check out Yank Performance and look at their 4L70 transmission. It is basically a seriously worked TH2004R transmission - like out of a Grand National. Even a plain TH2004R is a better transmission when compared to a comperably built TH700R4 - especially when you look at the gear ratios in each box. The TH2004R, or Yank's '4L70', is a 4spd OD transmission and you can option the Yank 4L70 to handle up to 850 ft-lbs . I know they make a kit for LS1 cars but I am sure they can put something together for a regular small block chev as well if you contact them....
If not, they also sell a stout TH400 that can be built to handle over 1000 ft-lbs !!!
I personally know a guy that runs a 4L70 kit in his LS1 car and it turns easy 10 second ETs.........
Good Luck...
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
[This message has been edited by Matt87GTA (edited October 11, 2001).]
Old Oct 12, 2001 | 12:19 PM
a73camaro's Avatar
Since torque is what breaks things, I'd be more inclinded to get a tranny from someone who says "it can handle XX ft*lb of torque" instead of saying "it can handle YY hp".
Old Oct 12, 2001 | 05:19 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
How about a lenco tranny these trannys can handle some serious power but be prepared to spend some money for it. When my next motor is built a 455 sbc all aluminum with twin turbos i will need a tranny that can handle somewhere near 1,700 hp that will survive street duty i know im nuts but why not you only live once later Dave.
[This message has been edited by SUPER CHEVY66 (edited October 12, 2001).]
Old Oct 12, 2001 | 05:55 PM
Jay 727's Avatar
I am currently running an all magnesium 501 ci small block that pumps out 2100HP , behind it is a custom 700R4 with a Beralcast case and all billet Beryllium internals, so far the stock 7.5 rear is holding up well.
http://tis.eh.doe.gov/be/webdoc1.html-ssi
[This message has been edited by Jay 727 (edited October 12, 2001).]
Old Oct 12, 2001 | 08:21 PM
Ions91Z28's Avatar
Umm...just curious if this is an F-body. If so, how are your plans for Twin Turbos going to happen?
91 Z28
Best Time Slip:
60' - 2.098
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Oct 12, 2001 | 08:22 PM
JETHROIROC's Avatar
Sounds a bit fishy to me....
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 12, 2001 | 11:03 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Yes, this will be for a 91 Firebird. Right now, I'm planning/blue printing everything that needs to be done. I'm almost complete in getting the insides. The engine will take a little more time because of college. The new engine will be twin turboed but I doubt that's gonna be anytime soon. I'm starting with the frame and suspension work first then moving on to the brakes. Engine will happen later. I will start taking pictures to document all of my work. I have a vision of what the car can and will be. Just need to get there.
RS Reaper
Oct 17, 2018 07:52 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Glowsock
Sep 11, 2015 11:09 PM
IROCZ1989
Sep 4, 2015 11:54 AM
