Will a 700R4 from a 2WD truck work?
Old Nov 11, 2009 | 09:54 AM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
yup, I'm cheap. Looking to switch my failing T5 to a Auto or a cheap T5. Well, it's more difficult to find an F-body T5 cheap than a 700R4.
I'm wondering if only the F-Body Auto's had the mounting holes for the Torque Arm, or if they all would. And, would I need a long or short tail 700R4?
Yep, I know there are plenty of people that hate the 700R4.. But, I'm looking at one on ebay for $40 starting bid, local pickup only. It was from a 1/2 Ton pickup.... I'm trying to find out what year.
I would go with a TH350 or 400 but I can't afford a different crossmember - I'm a poor college student.
Old Nov 11, 2009 | 10:04 AM
PV9685's Avatar
Re: Will a 700R4 from a 2WD truck work?
hmm, from some pictures I found it appears that at least the tail shaft housing would need to be swapped for an F-body one so that it has the mounting provision for the Torque Arm.
Old Nov 11, 2009 | 03:36 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
im looking into doing the same thing, i will attempt it this weekend, let you know how it goes!
Old Nov 11, 2009 | 03:44 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
In my Friend 84 Trans Am we used the trans from the 86 Caprice we got the engine from. All we did was change the tail shaft housing from a junk v6 700r4.
Old Nov 11, 2009 | 03:47 PM
Stephen's Avatar
Car: 87 GTA
The trans will fit, but you will hafta swap out the tail housing, or get a tranny mount with the torque arm relocation mount.
Old Nov 11, 2009 | 03:54 PM
Pierced_Zombie's Avatar
Car: 1984 camaro z28
Engine: 305 H.O.
Transmission: 700r4 automatic
thats right, i switched mine w/ a suburban and while your at it switch the spedo gears. itll save you some trouble while your down there and got it open lol
Old Nov 11, 2009 | 04:01 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
why switch out the speedo gears? also is there a way to hook up the manual(cable) speedo?
Old Nov 11, 2009 | 04:06 PM
Stephen's Avatar
Car: 87 GTA
Because chances are, the vehicle you get the tranny from, will have different rear gears. If so, your speedo will be off. Either a high or low reading.
Old Nov 11, 2009 | 09:24 PM
PV9685's Avatar
Yeah, I would defnitely change the gears before it's in. The previous owner of my car changed the rear.. My T5 has the wrong drive gear.. I don't want to switch the drive gear in a failing tranny, I would rather just put in a better trans with proper speedo gears.
Old Nov 11, 2009 | 09:47 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
will i even be able to hook up the speedo in my 86 to a 88 tranny?
Old Nov 11, 2009 | 09:52 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Yes just need to use your old cable gear driven housing. they swap over if its electric same animal. Put a 89 700r4 last year and it was electric. and my 86 was cable. All i did was switch out the gear housing.
Old Nov 12, 2009 | 12:17 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
no way! good stuff! i gained the convinence of using a friends car lift and hopefully tranny jack this weekend! let you all know how it goes! PV9685 when do you plan on doing yours?
Old Nov 12, 2009 | 07:20 AM
PV9685's Avatar
Well, right now I'm still in the planning phase... Though I am about to acquire parts over the next week. This has been something that I have thought about for a while (switching to Auto). Though I would have prefered finding an inexpensive T5 or T56.. of course I suppose I could use analogies such as pigs flying and cold days in he.....
So I will hold on to my T5 parts and swich over to Auto. Lucky for me the old owner (as incompetent as he was) put in a chip for an Auto.. Kinda sucked as my shift light always came on (it is the wiring for torque convertor lockup on an Auto).
So, so far.. I need to get - and swap a tailshaft housing so I'm using an F-Body one; check and change the speedo drive gear (driven will be addressed once determined); and find an Auto flexplater; Auto starter; Auto shifter... darn lol; not to mention Driveshaft length!
Old Nov 12, 2009 | 07:43 AM
Stephen's Avatar
Car: 87 GTA
Just pull the gauge cluster out, pull the shift light bulb out & reinstall the gauge cluster. Not a big deal to do & will eliminate the shift light coming on.
Old Nov 14, 2009 | 10:53 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
ok just got my tranny in. the speedo gears on both trannys are totally different, and the one on the 88(electric speedo) is pressed on and i couldnt get it off so i couldnt hook up my speedo cable!
Old Nov 23, 2009 | 06:20 PM
PV9685's Avatar
I have the electronic VSS on mine aswell, of course. I don't believe that the gear is pressed on to the metal shaft. If you look at the side of the gear on the shaft which faces the VSS, if I recall correctly it looks as if there are notches that "click" on to the shaft.
I put mine back in the trans abotu a week ago so I can't look at it... but pulling it off without cracking it may be tough. However, who knows - it may hold up to being pulled off just fine. If you do try pulling it off, put something below it like a crescent wrench so that you are pulling/pushing from the center. (So the gear is less likely to bend and eventually crack)
As for me, I wasn't able to get the 700R4 I was looking at - so it's going to be a little while until I swap.
However, I got a set of Bosch Design III's for $20 and an MSD coil for $5 so I have some items to keep me busy... along with plugs for the AIR injection exhaust ports
Terrell351
Jun 13, 2021 01:13 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Reddeath210
Oct 6, 2015 08:20 AM
squiggy2
Aug 9, 2015 09:30 PM
Leggman1
Aug 6, 2015 04:15 AM
