J turn?
Old Jul 19, 2011 | 04:15 PM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
J turn?
http://www.youtube.com/watch?v=v2DtrQ3gVIU
I won't break anything in the transmission if I do this stunt, no?
Old Jul 19, 2011 | 04:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: J turn?
Depends what you hit while you're trying it.
Old Jul 19, 2011 | 04:43 PM
Krishan's Avatar
Engine: 5.0 305 TPI
Re: J turn?
nothing.
but theoretically. I'm not too confident knowing what's rotating in the drivetrain. but it's not going to stress/break anything like driving forward and kicking into reverse?
Old Jul 19, 2011 | 06:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: J turn?
It'll stress all kinds of things.
Old Jul 19, 2011 | 07:17 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: J turn?
if you have a weak link in your trans or rear that will help you locate it .
Old Jul 19, 2011 | 08:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: J turn?
probably would work best with a manual trans, so you can pop it out of gear as your turn so it doesnt stall when you change directions....
dont try it.
Old Jul 20, 2011 | 12:36 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: J turn?
Short answer is yes. Maybe the first time, or the tenth or the five hundredth or more. Depends on your luck. It's not really any worse than doing a burn out or all out launch. Everything breaks at some point. Go for it. Have some fun. Fix it if you break it.
Old Jul 21, 2011 | 06:13 AM
EvilCartman's Avatar
Car: '82 Z28
Re: J turn?
Go in reverse, crank the wheel, drop the trans into drive, roll out like a boss. Every time you drive your car there's a possibility of something going wrong with parts.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
