Speedometer
Old Feb 3, 2012 | 12:02 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Speedometer
After swapping my entire suspension with a 1" drop, 16-15"wheels with larger tires, new axle, drums to PBR brakes, ls1 driveshaft I know my speedo is going to be off, is there a quick fix or is it easier to bring it to a shop for calibration?
Old Feb 3, 2012 | 12:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Speedometer
Change the speedometer gears in the transmission.
Old Feb 3, 2012 | 12:14 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Speedometer
Igotta take the transmission out and crack it open? what gears do I gotta change it to? I dont mess with transmissions.
Old Feb 3, 2012 | 12:28 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Speedometer
Easy fix, TomTom that displays Mph
Old Feb 3, 2012 | 06:02 AM
Re: Speedometer
I know
How so?
Suspension height, drive shaft material, brake design, and so on, have NO effect on it. Tire OD will affect it ( ACTUAL MEASURED OD - not wheel size, and not "trade size" "calculated" OD) and gear ratio; all the rest of that is irrelevant.
NO you don't have to take out the trans and "crack it open". Changing the gears is as easy as changing the oil, maybe easier. No... make that DEFINITELY easier. Go here http://www.transmissioncenter.net/sp...n_______va.htm Sorry it's so hard to find stuff on that site, the page design (or rather, lack of it) isn't MY idea.
Old Feb 3, 2012 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer
What 'reins' do you have? Manual or auto?
JamesC
Old Feb 3, 2012 | 09:36 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Speedometer
700r4
Old Feb 3, 2012 | 09:51 AM
JamesC's Avatar
Re: Speedometer
http://sethirdgen.org/vss.htm
JamesC
Old Feb 3, 2012 | 09:58 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Speedometer
Sweetness, that dont look bad at all. Thanks a bunch
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
