Replacing the clutch difficulty.
Old Apr 4, 2012 | 05:33 PM
69dart69's Avatar
Hey all im thinking about picking up a 1984 trans am 305 5 speed, however the owner says the clutch is gone, can anyone tell me how difficult it is to replace/fix this ? all info is appreciated thanks.
Old Apr 4, 2012 | 05:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Replacing the clutch difficulty.
everything just onbolts, but you have to pull the trans out, so thats a little bit of work. the t5 weights about 80 lbs dry? doing this on a lift will al the right tools is not a hard job, but i t cam e be done with just a jack, jackstands and muscles.
Old Apr 4, 2012 | 05:56 PM
69dart69's Avatar
Awesome thanks, dropping the trans wont be a problem then.
Any recomendations as to what clutch package i should be going for or do you think a stock replacement is fine ?
Old Apr 4, 2012 | 06:58 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Most likely the stock replacement would be fine depending what you are using your car for. Sorry for jumping in.
Old Apr 4, 2012 | 08:52 PM
I can swap one laying on my back in my garage in about 2½ hours.
It's the lightest manual trans for front-engine RWD cars that I know of. Easiest to deal with in every way. Total piece o cake.
A "stock replacement" would be fine... I'd avoid the AZ specials and such, but yerbasic Ram, CF, etc. type of deal should be fine. Be aware that virtually all of the clutches themselves are the same, and come from Valeo or LUK or the like; the discs are about all that's different.
Make sure you replace the pilot bearing!!! This cannot be adequately emphasized.
Old Apr 4, 2012 | 08:54 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Hardest part will be removing the dips stick and retaining bracket, and getting it back in!
Old Apr 5, 2012 | 07:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
What dip stick?
Old Apr 5, 2012 | 04:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats easy! but finding those parts first is the hard part....
Old Apr 5, 2012 | 06:33 PM
Edwardgp's Avatar
Engine: 454-350
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
