REAR END BUILD PROBLEM
Old Mar 5, 2017 | 04:24 PM
scoobyct's Avatar
Car: 89 Camaro RS
Engine: GM 350
Transmission: 700 R4
So i picked up a posi rear end bare with nothing included like brake lines or calipers etc. So im stuck building it from scratch. Whats a good place to find the brake lines and blovk that they meet up to. Also what brackets am i missing that the caliper brake hoses clip onto. Any pictures of one close up or a blow out diagram would be great. I have picked up new e brake cables ...rotors and calipers with brackets. I have a sway bar i put on. But wondering what more i need as far as brackrts or how the brake lines assemble. Thanks any help is great
Old Mar 5, 2017 | 06:01 PM
Re: REAR END BUILD PROBLEM.
What rear?
Old Mar 5, 2017 | 06:19 PM
89rubberburner's Avatar
Car: 89 Formula
Axle/Gears: 9Bolt 308 gears
I'm rebuilding a 9 bolt right now. Ordered new steel brake lines and braided lines to replace the rubber ones. Ordered them from Summit. Haven't received them yet. But from the picture it looks like the mounts at the end of the axles come with the set. Mine has rear discs so there is a short rubber hose at
the caliber. Drum brakes wouldn't have that. Just steel lines right to the cylinder. The Center "t" comes with the set too They seemed to have lines for most rears.
Old Mar 6, 2017 | 06:27 AM
scoobyct's Avatar
Car: 89 Camaro RS
Engine: GM 350
The rear end is off a 91 firebird formula and going on my 89 camaro. 10 bolt posi. I also believe its a couple inches longer in width as well. Looking for a kit with the lines, ill be checking out summit as well.
Old Mar 6, 2017 | 06:38 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If it is longer then you may have picked up a 4th gen (93-02) rearend. Make sure its what you want b4 you spend money on it.
Old Mar 6, 2017 | 07:11 AM
scoobyct's Avatar
Car: 89 Camaro RS
Engine: GM 350
Yeah i think its what i want....its already in and i took the time to coat it in por15 so gonna live with it. It will give the camaro a wider look to it so ill take it lol. But ill have to find some lines for that rear.
Old Mar 6, 2017 | 08:04 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
If you have a 3rd gen rear you can get lines here. I am not sure where the best 4th gen place is.
http://www.thirdgenranch.com/catalog/category/5353654
Old Mar 6, 2017 | 09:22 AM
big gear head's Avatar
A '91 rear end is exactly the same width as the '89 rear end. '82 to '92 are the same width. If your rear end is wider then it is not a '91, it's a '93 or later. You must figure out what you have before you can get parts for it. If you order brake lines for a '91 and you have a '93 then the brake lines will be too short.
Old Mar 7, 2017 | 06:32 AM
scoobyct's Avatar
Car: 89 Camaro RS
Engine: GM 350
So now i just decided to get a 3rd gen rear end from a 89 GTA and its complete so we should have less problems. Just need to find brake lines for that rear end. Any suggestions?
Old Mar 7, 2017 | 07:47 AM
midias's Avatar
I would probably use the link I already provided for 3rd gen brake lines
oil pan 4
Wheels and Tires
Dec 5, 2016 06:51 AM
hectre13
Oct 6, 2016 09:14 AM
Toad1
Sep 22, 2016 10:04 AM
customblackbird
Sep 19, 2016 08:50 AM
chas0218
Sep 15, 2016 05:22 PM
