1992 4L60 TC lockup ?'s
Old Jan 11, 2018 | 04:15 PM
mjgord51's Avatar
Car: 14 & 96 Camry's, 68 C10,70 Z28
Engine: Depends what vehical I'm driving
Transmission: Also depends which vehical
Axle/Gears: Also depends on vehical
Hello all, I'll start out by saying I do have a 4L60 trans But it isn't in the Firebird it was made for. It now resides in my 68 C10 SBC (305) Truck.
My question is being its in a transplanted vehicle and not hooked up to what it would have been in a Firebird is there any way I could find out what or how it was hooked up to when in the Firebird?
I am looking for info so that I can have the trans hookup into the TC lockup mode by nothing other then what it would have been in the Firebird. Backyard aftermarket parts & wires with toggle switch's is what I am trying to avoid.
thanks in advance for any help or links, Marvin
Old Jan 11, 2018 | 05:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1992 4L60 TC lockup ?'s
You most likely can wire stock(-ish) The 4-position connector on the side of the trans should have 3 terminals in the harness connector to it:
Power, +12 volts from brake pedal switch. Open when on the brakes.
Ground, comes from the ECM to lock the TCC. Also goes to ALDL connector.
4th Gr switch, tells the ECM when the transmission is actually in OD (4th gear).
RBob.
Old Jan 11, 2018 | 06:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Here’s the pigtail needed
https://m.ebay.com/itm/Torque-Conver...28?_mwBanner=1
Old Jan 11, 2018 | 06:37 PM
mjgord51's Avatar
[QUOTE=Tuned Performance;6194271]Here’s the pigtail needed
https://m.ebay.com/itm/Torque-Conver...28?_mwBanner=1[/QUOTE
Thanks but the pig tail isn't my worries
Old Jan 11, 2018 | 07:13 PM
mjgord51's Avatar
RBob.
Yes the rear of the trans connector hole closest to the trans is a dead head hole with out a pin. So is what you are saying I could replace my two prong brake light sw with a four prong sw and run a wire from it to the trans connector (at what point, or pin) and with a keyed hot wire to the trans connector (what pin) then that's it? What goes on the other prong of the brake light sw? Not sure where this ground comes in or goes too? Does the trans connector have a ground spot/pin to connect a ground wire to it and ground it to the trans or frame?
If I am understanding this right the brake light sw kinda is taking the place of the ECU/ECM since my truck is a 68 C10 that isn't equipped with one ECU/ECM ?
This will make the TC lockup and un lock when slowing down in the same way and function the same as it would be in its donor car (firebird) as this trans did come from one ?
Old Jan 12, 2018 | 08:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The brake pedal switch is fed IGN+ switched power. The other terminal on the switch goes on to the trans. This switch opens when the pedal is depressed. Forcing the TCC to unlock.
The ECM provides a ground to energize the TCC solenoid in the trans.
Since you aren't using an ECM there are vacuum operated TCC sets available. GM used them in various vehicles that didn't come with an ECM. There is a good thread here on TGO about them.
The picture is how GM wired the '92 f-body trans connector. The letters to ID the terminals are molded into the connectors. Be sure to get the power to the solenoid with the proper polarity. Otherwise the diode pops.
RBob.
Old Jan 12, 2018 | 11:29 AM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tran...up-switch.html
Old Jan 12, 2018 | 06:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
(via PM):
Originally Posted by mjgord51
Not sure what you mean by "Proper Polarity"?
The TCC solenoid has a diode across the coil. This is to suppress the high voltage kick back when the solenoid is turned off. If the +voltage and the -voltage is switched, it pops the diode. So then need a new TCC solenoid.
The remainder of the PM is discussed prior to this post.
RBob.
Old Jan 13, 2018 | 11:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
See this thread for how GM did 3rd gen f-body TCC lockup without an ECM:
https://www.thirdgen.org/forums/tran...up-tourqe.html
RBob.
Old Jan 13, 2018 | 01:28 PM
mjgord51's Avatar
RBob.
I will look over your link later today, thanks.
I should have ask this question first (maybe dumb) but I really don't know the answer.
DOES THE 4L60's IN ITS STOCK 1992 FIREBIRD PLATFORM HAVE A LOCKUP TORQUE CONVERTER SYSTEM STANDARD EQUIPMENT FOR THE TRANS OR DOES THIS TRANS NEED A " AFTERMARKET LOCKUP KIT" TO DO THE JOB EVEN IF IT IS IN ITS STOCK FIREBIRD TO LOCKUP?
Old Jan 14, 2018 | 06:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In '92 the ECM controlled the TCC lockup. Factory stock. I explained a lot of this is my previous posts within this thread.
RBob.
Old Jan 14, 2018 | 09:10 PM
mjgord51's Avatar
RBob.
I must have missed it, I have the same question in other Forums just worded differently but kinda asking the same thing. There has been from other forums members giving there rendition of there way in a setup for locking a torque converter in 4th gear. Just like the song says "there is 50 ways to leave your lover" and as many ways to lock up the TC as well.
***I will re read back to see what I must have missed.***This might be redundant but I will ask it anyway or again. If the ECM's job was just to supply a 12v signal to the trans to lock it up in 4th gear when the trans went into 4th cant that same 12v signal be delivered by a Keyed On Ignition type signal or from anything that is 12v hot only when ignition is on?
It just seams simple that the ECM is taken out of the equation and a simple fix would be to activate the system by a 12v signal? Kinda curious why there is so many different ways in doing a simple job. RBob I will go back over this thread, thanks
Old Jan 15, 2018 | 07:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ECM doesn't supply the +12 V. See my first post in this thread.
RBob.
Old Jan 15, 2018 | 11:11 AM
mjgord51's Avatar
RBob.
I did re read it, thanks again
bubbachuck7
Aug 9, 2012 05:16 PM
Z28GEN3
Mar 3, 2008 03:58 PM
MTchevy1
Feb 6, 2007 02:18 PM
foney_email
Sep 15, 2002 09:01 PM
illegal87
Mar 29, 2001 07:38 AM
