88 irocz auto TH700R4
Old Nov 24, 2019 | 02:34 PM
leith's Avatar
Transmission: auto
Hi Guys I have had a rebuild done on my TH700R4 the guy had a right battle with it if had been blown up by previous owner as the casings had been welded in places and a right mess in side so he changed casings etc .So I have if back seems to shift fine up and down driving it easy for a1000 miles but if I pull away a little sharp it changes up to second and back to first then back to second then up to 3 and forth as it should if I drive it softly it changes normal first to second third fourth is it just braking in or is the Tv cable out of adjustment It has done about 150 miles now.Thanks for any ones help .
Old Nov 27, 2019 | 05:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: 88 irocz auto TH700R4
Do adjust the TV cable to spec first, trying to read through your issues though, it seems something may not have been assembled correctly.
With only a 1000 miles on it, I'd head back to the rebuilders and have him take a ride in it.
Old Nov 27, 2019 | 06:23 PM
Tzych's Avatar
Car: 1988 GTA
Engine: 5.7 TPI
Definitely sounds like the tv cable is a little loose. Needs proper adjustment right away. Can do damage driving with improper adjustment. You’d be surprised how a little adjustment can do wonders.
Old Nov 28, 2019 | 08:12 AM
leith's Avatar
Transmission: auto
Thank you Tzych and Mike ,I took a look to day at the TV cable throttle body linkage end I pulled the TV cable just under a quarter of an inch to wards the front there was slack there what had happened the screw on the small adjuster at the end of the cable was loose wich caused the cable to slip so pulled up the slack and tighten the screw then I give it a drive and give it a bit of gas it changed up perfect 1st 2nd 3rd 4th no messing about.
So thanks again guys your advise was great.
Old Nov 28, 2019 | 08:16 AM
Tzych's Avatar
Car: 1988 GTA
Engine: 5.7 TPI
Awesome!! Glad to hear this. Now you can enjoy it properly. Glad I could help
Old Nov 28, 2019 | 10:28 PM
Pro Built Automatics's Avatar
I would double what ever you can on the TV cable so as to it never coming loose again. Make sure that the TV cable is tight at WOT.
Old Nov 29, 2019 | 08:00 AM
Tzych's Avatar
Car: 1988 GTA
Engine: 5.7 TPI
Yes great point... and also make sure you aren’t limiting full accelerator travel of WOT by the TV cable.
Old Dec 1, 2019 | 01:00 AM
I agree with that.
Jcase350
Sep 4, 2020 05:50 AM
ROADKILL76
Nov 8, 2013 06:10 PM
Chuck Haynes
Jun 3, 2003 09:53 PM
MrMike99
Aug 17, 2002 03:15 AM
85cam
Nov 13, 2001 04:04 AM
