Pivot ball problem
Old Jan 14, 2020 | 12:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Pivot ball problem
Hi, sorry about the earlier rambling freak out post. It seems the same issue I had 6 months age when the clutch needed replacing after 12 years now happened after only 6 months. The pivot ball got very worn around the edges and got the fork sliding into the bearing retainer shaft it rides on. At least it didn't break it off yet this time. The fork doesn't have that great of a smooth surface on the dip indentation where the pivot goes, but the not very hard steel of the pivot ball wears down really fast. It was well lubed with moly grease and only covered maybe 2500 light driving miles. Yikes!
Does anyone know how or where I can find the pivot ball for this 92 5.0 Camaro with a T5 that is harder steel like the one that was in before???
All I can find is the ATP-JX112 that I have in there now. I really need a better one desperately
At first I thought the TOB was damaged but it is apparently self aligning and seems to be working fine.
Any chance a better fork would help any?
Thank you, Henry
Old Jan 14, 2020 | 06:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Pivot ball problem
Oer ?
maybe call them to get the part number
https://www.ebay.com/itm/1983-92-CAM...682?nav=SEARCH
Old Jan 14, 2020 | 06:17 PM
Engine: Lb9
Transmission: M20
Or Lakewood https://www.summitracing.com/parts/lak-15501
you can check application listing
Old Jan 14, 2020 | 06:26 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, the first one looks like the same one I have now. I was looking at the Lakewood one but I think it only fits the Lakewood bell housing and the thread is different. Was going to check that out for sure tomorrow
Thanks, Henry
Old Jan 14, 2020 | 07:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
OOPS I rechecked the applications and it may fit after all!! Wow, that would be great, thanks
Old Jan 14, 2020 | 07:33 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
After rechecking again, it only shows this part fitting up to the 91 Camaro. I thought the 91 and 92 cars and matching T5s were the same for 5.0s. Could there really be a difference? I guess I'll try and see if I can get an answer tomorrow. Does anyone know for sure that there is in fact a difference?
Appreciate any assistance
Henry
Old Jan 14, 2020 | 09:22 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Henry
I would highly doubt they would have changed the thread pattern for the '92 model year. The clutch forks all appear to be the same so I bet the pivot ball is as well.
Old Jan 14, 2020 | 09:28 PM
Drew's Avatar
Could try searching for Mr Gasket 3855G. My 1998 Mr Gasket catalog says it's the same as the Lakewood 15501, lists it for ALL GM applications, and recommends it with all Lakewood bellhousings. Pretty sure I've got a 1998 Lakewood catalog around here somewhere too, but I'm not having much luck finding it. Autometer, Lunati, Milodon, Lingenfelter, Mr Gasket...
Oops, spoke too soon. Went to put the Mr Gasket catalog back on the shelf and found the Lakewood book. Not a ton of info, but there you go.
Old Jan 14, 2020 | 09:40 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, I think their applications program is defective. It says this item has a 13/16 thread which fits older GM products but certainly not mine. Who knows.
Anyways, Camfire Dave on Ebay said he'd send me a nice used OEM one instead of the listed one. If that comes true I'll be a happy guy.
Thanks and wish me luck.... Thanks Drew, the catalogue also shows the thread to be 13/16 which is not exactly compatible with the part that fits with a M22-2.0mm thread
Good thing I didn't try to get it, sheesh!
Henry
Old Jan 14, 2020 | 09:54 PM
Drew's Avatar
You could always cut the stud off the ATP part, then drill/tap it 7/16-20 and thread in the Lakewood stud. AKA turn it into an adapter.
Old Jan 14, 2020 | 10:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Thanks, you never know. It's always good to have options
Old Jan 14, 2020 | 11:33 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Drew's suggestion is a totally solid solution when you want to solve the issue without welding to repair.
The 84-92 V8 bellhousing ballstud is M22 x 2.50 thread.
Old Jan 15, 2020 | 08:11 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
This says up to 1993 maybe check it out I like hays stuff
https://www.holley.com/products/driv...s/parts/84-119
Old Jan 15, 2020 | 09:48 AM
Drew's Avatar
Hmm... Now I have to wonder if I've got a Hayes catalog on the bookshelf from 1998. LOL It's funny how Hayes, Holley, Lakewood, Mr Gasket, Hooker, and so on are all part of the same corporate conglomerate. I suppose as long as business is good, it's ok. But if the corporation takes a hit, they all take the hit. That and it seems like when these companies get assimilated product lines get dropped, products get cross-packaged, like the Lakewood stud in Mr Gasket packaging, and so on. At least the Hayes part doesn't appear to be the same physical part as the Lakewood/Mr Gasket.
Old Jan 15, 2020 | 12:52 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
This seems like a good solution, but the Lakewood one mentions hardened steel. If the ATP part's steel is as cheap as it seems to me wouldn't that present a problem withstanding the pressure that the threads put on it during usage. Seems like they might not hold. Now I do still have my old original one that is much harder steel. IF I could get it tapped I would feel better about doing that.
Old Jan 15, 2020 | 12:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Except there is no way the threads are the same over that range of years. Somebodys data bases are screwed up
Old Jan 15, 2020 | 01:06 PM
Drew's Avatar
The weakest mild steel is going to be stronger than the cast aluminum bellhousing. I wouldn't worry about it.
Old Jan 15, 2020 | 01:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, good point.
henryd3
Apr 21, 2020 12:33 PM
archer472
Jul 1, 2012 09:36 AM
RU-QWIK
Jul 19, 2008 02:56 PM
ejm
Jun 21, 2005 12:16 PM
scubas_90rs
Dec 23, 2004 03:40 PM
