700 R4 question
Engine: 305 5.0 TBI
Transmission: 700-R4
700 R4 question
At 75 mph should your rpm be topped out in 4th gear? I had the transmission rebuilt, not sure. I mean it will do 80 etc.but it's pushin it.
And it will stay high rpm the whole time?
Is there a way to turn the over drive off?
Ive read that turning the overdrive off, allows the car to lower its gear.
It stayed 4.9k RPM the whole time on a 8 hour trip. It has always driven like this , it seems fine. I was just wondering if thats normal?
I'm the same age as the car so I'm not sure if this is how it was back then or not.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: 700 R4 question
holy smokes. No way man.
definitely
not
you drove it for 8 hours at 5,000 rpms?!?!?
definitely
not
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 700 R4 question
Your tach is obviously wrong...
Car: check
Engine: check
Transmission: check
Re: 700 R4 question
https://www.thirdgen.org/forums/elec...meter-fix.html
Going by a seat-of-the-pants guess, at 80 MPH the engine RPM should be in the low 2 K RPM range. That is if the stock rear gears and not a higher ratio gear set is in place.
Note that overdrive is another gear in the transmission. To 'turn off' overdrive move the shifter from the OD position to the D position.
Torque converter clutch (TCC) lockup is different then overdrive. Can unlock the TCC by slightly depressing the brake pedal. At cruising speeds the tach should bump up a bit as the torque converter is now slipping.
RBob.
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: 700 R4 question
man for all we know maybe someone swapped in a 6.50 gear for the dirt track. Does this thing have a roll cage by chance?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: 700 R4 question
Car: 1991 RS
Engine: 5.0
