Excessive distance between Throwout Bearing and Pressure Plate
Old Mar 22, 2025 | 06:56 PM
grimaro's Avatar
Car: 1986 Chevrolet Camaro
Engine: 350 SBC
Axle/Gears: 4.10
Hey all, need some help. I'm doing a t5 swap on my 1986 Camaro and I've gotten to the point where i'm installing the transmission, but i've run into a snag. There's roughly an inch of distance between the throwout bearing and the pressure plate, and with the clutch slave installed, the throwout bearing sits against the pressure plate as such an angle, it gets in the way of the splines of the clutch.
My Camaro has a Gen 1 SBC with the large flywheel pattern, and the swap kit I got came from a 1987 Z28. I bought a lightweight flywheel for a Gen 1 block from Speedway Motors, and used the Pressure Plate/clutch/Throwout Bearing/Clutch Fork from the '87 Z28.
I must be missing something. Could the flywheel I bought be too thin? I'm kinda at a loss. Here's some pics of the setup, and the angle the throwout bearing is sitting at
I could possibly buy a stock flywheel for a 1984 Z28, but that's just a hunch..I don't know for sure. Would love some help or info
Old Mar 22, 2025 | 07:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Excessive distance between Throwout Bearing and Pressure Plate
Used pressure plate 🧐, are you sure the fork is for that bell housing ?
Old Mar 22, 2025 | 07:20 PM
grimaro's Avatar
Engine: 350 SBC
Axle/Gears: 4.10
Considering it all came from a 1987 Z28, saw the vehicle in person, and watched all the parts get pulled from the vehicle, I can confirm it came from that car. Bellhousing and all
Old Mar 22, 2025 | 07:24 PM
grimaro's Avatar
Engine: 350 SBC
Axle/Gears: 4.10
Furthermore, here's more photos of the clutch fork lining up directly with a replacement clutch slave for a 1984 Camaro, so I don't believe it's a clutch fork issue
Old Mar 22, 2025 | 07:26 PM
Fork not installed to bell housing properly
Changing the flywheel won't change the centering of the fork in the hole there, unless it moves the center of the crankshaft over to the side somehow
There's a little spring kind of thing on the back side of the fork with 2 fingers; those fingers are supposed to grip the pivot ball
Old Mar 22, 2025 | 07:27 PM
Engine: Lb9
Transmission: M20
lost me with the 1984, maybe @sofakingdom has some wisdom to share
Old Mar 22, 2025 | 07:31 PM
Engine: Lb9
Transmission: M20
🤣, post while im responding
Old Mar 22, 2025 | 07:37 PM
OK cool
​​​​​​​Good luck with that
Old Mar 23, 2025 | 07:20 AM
grimaro's Avatar
Engine: 350 SBC
Axle/Gears: 4.10
OK cool
Good luck with that
Found my issue, Throwout Bearing was inserted too far into the radius of the shift fork, I pulled it out a little and it instantly snapped into place. Now it's flat against the pressure plate, and everything lines up correctly. It's the small things that get you, lol. Transmission going in later today
Old Mar 24, 2025 | 08:49 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
<snip> Transmission going in later tody
The latter would have resolved the initial perceived (non)issue.
Throwout bearing rides the sleeve on the trans.
Now if you tightened the pressure plate bolts while the disc was aligned slightly high of center, you'll have a successful stabbing. If you paid no mind to disc alignment while tightening them, you'll do it twice.
seanof30306
Jan 18, 2019 03:35 PM
Vice04
Jul 11, 2009 10:39 PM
Dewey316
Mar 3, 2002 10:36 AM
89formula#1
Jan 31, 2002 09:18 PM
a73camaro
Aug 21, 2001 01:11 PM
