The dreded sparkplug
Old Nov 8, 2002 | 08:12 PM
PeNZ's Avatar
Ok if you have a 90-92 bird or maro, was the best way to change that damn spark plug on the left side, the first one twards the front of the car?
Old Nov 8, 2002 | 08:45 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I havn't found any good way yet.
But use an adjustable angle socket wrench, it helps....
Old Nov 9, 2002 | 12:18 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Getting the plug is easy. You just need a swivel and a few long extentions. GRAVY. My only problem with that plug is getting the boot on and off. My fingers need to be a little bit longer.
BTW, if you think that plug is hard, don't ever buy an LT1.
Old Nov 9, 2002 | 01:35 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
or a 4th gen for that matter.. had to change the plugs from under the car..
-mike (loomdog)
Old Nov 9, 2002 | 07:46 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
The easiest way I have found to get to that spark plug is to just follow the egr pipe down to the exhaust manifold. Unbolt the heat shield and pipe. Then unbolt the metal tube that it attached to the plenum on the side. Pull off the pipe and undo your spark plug. It only takes a few seconds to take that pipe off and it will be LOADS easier than trying weird extensions and swivels. Hope I was some help!
Old Nov 9, 2002 | 08:09 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Don't think mine has that metal bracket. Gonna have to take a look myself.
Old Nov 9, 2002 | 09:07 AM
Vader's Avatar
Originally posted by CaliCamaroRS
...if you think that plug is hard, don't ever buy an LT1.
Amen, brother.
#2 is a real treat on those - almost as much fun as changing the distributor and rotor (done that, too).
Old Nov 9, 2002 | 10:09 AM
KED85's Avatar
Do it on a 1978 Monza with the V-8 option.
Just different length extensions & a plug socket & a wrench will usually take care of 99% of hard to reach plugs.
Old Nov 9, 2002 | 01:36 PM
vortechLT1's Avatar
Originally posted by Vader
Amen, brother.
book time is 4.5hrs
after doing a few my self I can get it done pretty fast
(great for making money)
Old Nov 10, 2002 | 01:29 AM
Engine: LH0 3.1L
Originally posted by vortechLT1
book time is 4.5hrs
Heh, I did the plug wires on a '96 Impala and it took me 4 agonizing hours. We flagged 3 hours on the job. One of the RARE times that ACTUAL time was more that FLAG time.
Although it was my first time. I could defintitely beat 4 hours now.
ME=glad the LT1 only lived for 6 years.
Infested
May 22, 2018 11:56 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
pm_
Oct 16, 2002 12:33 PM
Mike86Z28
May 27, 2002 05:57 PM
WaynesRS
Feb 12, 2002 01:06 PM
