145mph speedometer in V6?
Old Jan 3, 2003 | 01:47 AM
zer0321's Avatar
I tried a search and I couldn't find any "for sure" results. So here it goes:
I want to upgrade my 1992 (electronically driven) 110mph speedometer to a 145mph (electronically driven) speedometer from a Z28, here's my question, can I change out the speedometer only or do I need to swap the whole guage cluster? if I have to swap the whole guage cluster, what do I have to do to get my (new) tachometer to read correctly?
Thanks for your help!
Old Jan 3, 2003 | 10:31 AM
camaro89dude's Avatar
From what I have heard, you can just switch speedos.
Old Jan 3, 2003 | 09:06 PM
IROC57TPI's Avatar
If you ever seen the other side of a buck twenty then I think it would be a worthy mod. But I doubt it Could save that money for a set of headers or something.
In answer to your question... yes it would work. The clusters all operate on the same voltage signal.
Old Jan 4, 2003 | 01:22 PM
KED85's Avatar
Yes and no.
What's the diff?
On the V-8 gauuge set up, you'll see oil pressure reading to ONLY 60 lbs.
That's for V-8 POWERED ONLY.
Our V-6 rides have oil pressure readings to the number 80 and the matching sensors.
The speedo, swapping in & out, shouldn't be a dramatic difference as they are same "frame" (plastic housing & circuit board).
The TACHS, flip over gauge packages & you'll see a "6" on one tach circuit board & a "8" on the other.
Solution, you should be able to just swap the speedo heads from one to another.
Swap/replace the 145 speedo head to the V-6 gauge package & IT SHOULD BE FINE.
But don't quote me, as I've never experimented with the electric drive speedo items.
My 1985 Firebird has mechanical speedo. I have a V-8 gauge set that I converted to V-6 by swapping tach circuit boards & swapping the V-6 oil pressure
I plan on swapping in a 160 speedo head from a 70's Firebird or a spare Corvette one (from the 70's).
For my mission, my problem is making the face numbers for reading that high. Computer graphics here I come!
My Firebird going 160MPH?????
I'd offer it for that stunt only if they dropped my car on a few stupid turban heads overseas.
Can you say "going out in style!"
Old Jan 4, 2003 | 02:20 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yeah, you can't separate just the speedo from a 90-92 dash. You'd need the whole thing and the oil pressure gauge is wrong just like Karl said, and the tach probably won't work right....still not sure about that one..
Old Jan 4, 2003 | 11:48 PM
zer0321's Avatar
I just hate the idiots when I give them rides that say: "whaa...your car can only go 110, my mom's caravan goes to 120"
Anyways, I'm planning to upgrade to a turbo 3.8 out of a TTA this summer, so the speedo will be put to good use!
so it sounds like I have to buy the guage cluster, and then swap my v6 tach and oil pressure guages into it....correct?
Old Jan 5, 2003 | 02:49 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
TTA's only have a 140 speedo. Since you are planning on installing a LC2, I have a TTA pass. side header for sale if interested. Its the hard one to find.
Old Jan 5, 2003 | 07:04 AM
KED85's Avatar
That theory worked correct for my 1985 gauge cluster.
Yours could still be different solution, too.
You're upset about someones comment who owns a MINIVAN!
Tell the guy, next time, just walk that fast 'cause you ain't riding with me no more!
Next thing he'll say is the minivan has more room & you'll be figuring out that solution for him, too!!
I got it, hit the hatchback opening & boot him out!
Old Jan 6, 2003 | 06:25 PM
zer0321's Avatar
yeah, I've banned many people from my car ...
Actually, I don't care very much about what people say about my car, I do what I want with it, and I would like to have a 145mph speedometer, it's not really a big priority for me right now, I'm just planning ahead so I can watch for a good deal....and besides, If it is possible there is no reason why I shouldn't upgrade
Old Jan 8, 2003 | 04:07 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Is it hard to swap the two gauges to make it work?
Old Jan 12, 2003 | 11:29 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Yeah atleast the tach...4 cyl to v-6 to v-8 tach setting are all different...When I installed my new tach in my Z28 it was set on 4 cyl. It said I was shifting at 10,500 RPMs...heh heh
Old Jan 21, 2003 | 07:13 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
WRONG
i just took my cluster out today to install my white face 25th anniversary gauges, the cluster is in 3 parts!! the speedo/tack/and middle cluster!!
BTW my speedo hits 120 now!!
now i know where i am over 110
Old Jan 21, 2003 | 07:26 PM
zer0321's Avatar
cool, looks like I'll be upgrading then!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
