2.8 Intakes & Air Cleaners
Old Aug 17, 2005 | 05:42 AM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
My daughter just purchased a 1987 Firebird with the 2.8L 6 banger.
Are there any good/custom air cleaners or intakes for these cars?
Any pictures out there? I would like to see what others have done with their 6 cylinders!
shipfitter
Old Aug 17, 2005 | 12:01 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Their is none to buy, you will have to fab something up with pvc tubing, and a 3" "*****" filter.
Old Aug 17, 2005 | 04:39 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
noooo........change it to an edelbrock intake with a 390 holley topped with a chrome base k/n filter and k/n extreme flow lid.......and breathers in theedelbrock valve covers.
Old Mar 27, 2009 | 07:01 AM
iaqdix's Avatar
Re: 2.8 Intakes & Air Cleaners
I think you should try to search into google for more information about that air cleaners man....
_________________
Trion Air Bear
Old Mar 27, 2009 | 11:30 AM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
(Edit) Nevermind, you have a firebird, different intake. But you can cut the bottom of that air box, too. Or go to a junkyard and find this intake from the camaro. Wow, old post, 4 years old now.
You could do this:
Cut the bottoms of the air boxes out to create more air flow, and then use K&N filters.
Old Mar 27, 2009 | 12:42 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Thats what mine looks like. Mine is a 3.1 not a 2.8 but its the same set up
I used 3in PVC and a massive K&N filter. Alot of people use the smaller filter but i had this one laying around. You will have to find somewhere to put your sensor. Mine is one of those small intake temp sensors so all i had to do was drill a 5/8 hole near the front of the intake and thread it in there nice. I topped it all off with 4 in flex tubing used for air ducts. Overall it looks amazing in person and I noticed a nice sound of it sucking in as much air as it needs. It helped a lil bit on throttle responce and also gave the exhaust a lil deaper note.
Old Mar 27, 2009 | 03:12 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I think you should look at the date of the posts first before you resurrect an old thread like this...
Old Mar 27, 2009 | 03:14 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
There are actually "kits" sold on ebay that come with all the chrome tubing, bends and a K&N knockoff.
And I kinda doubt this guys daughter wants him taking off the manifold and making her car carborated. Fuel injection is the way to go anyway.
Old Mar 31, 2009 | 07:58 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You could do this:
Umm, Camaro intakes don't work on the Bird. Lower hood clearance, you know. Which is why GM used 2 different setups between.
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
