2.8 3Q's
Old Oct 16, 2006 | 09:21 AM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
2.8 3Q's
Q1: i have a 2.8 camaro and it has the maf unit i was wanting to swap to a 3.1 map unit ecm,wiring ect, just wondering is there a better advantage to a map than a maf as in tuning wise with no restriction on the dumb sensor?
Q2: no on the 2.8 TB iwas wonder if theres a way that a machine shop can bore out my TB with one hole insted of two almost like the performance fiero TB but i call a Fiero Distributor in cali they said its the as a firebird just that the plenum sits sideways but it would bolt up to a fbody 2.8 just wondering if anyone has done it??
Q3:now on the edlebrock 2v intake i cant seem to find out if it just for carbs or can i put my plenum on it still anyone know?
Old Oct 16, 2006 | 09:56 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
2.8L ouch..
Are you trying to get more power out of the 2.8?
I had a 2.8 in my 84 Camaro, and it ran like a rock.
Replaced it with a free 403, lots of work, but was fun to drive after that.
Sorry I don't have any advice on how to give a 2.8 more power except for change the engine.
If you decide to build the 2.8, I would love to hear how it turns out for you in the end.
I guess I really wonder is, how much power can you make with a 2.8L.
Old Oct 16, 2006 | 12:38 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
well far as i herd was around 400hp to be honest with a chip and headers yah know the works cam,lifters,thermo every thing you can possible do with 60 trim turbo when i talked to a guy at night under fire norwalk raceway car builder now i dunno if that was twin or single i didnt ask he didnt mention but im thinking twin but damn that big of a turbo 60 trim you would think it would blow out the bottom ?? but i believed him he raced a drag car and build cars yah know so thinkin maybe so0 but damn can u emagine to have under a hood a tiny *** 2.8 with viper power almost geeze would be tight but not for most of us i cant really believe it but only some know
Old Oct 16, 2006 | 04:53 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Originally Posted by ezysk
2.8L ouch..
not trying to start anything, but why did you post if you dont give advise on the 2.8?
onto the original questions:
Q1: yes a map system is much better for tuning.
Q2: not sure i completely get what youre asking? your TB has only one hole, so if youre asking if it can be bored out, yes with a custom valve made for the OS bore. but there are lots of other restrictions to overcome before the TB.
Q3: carb only. if you look at the top of it, its only got a big opening, it doesnt have each runner for the fuel injection, and the plenum wouldnt bolt to it anyway.
Old Oct 16, 2006 | 05:13 PM
daves12secV6's Avatar
2.8L ouch..
412/467 hp/tq with a 3.1
so the 2.8 would be slightly less power,i made 225hp with a n/a 2.8 but never dynoed it with the turbo
Old Oct 16, 2006 | 06:17 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Axle/Gears: ??? / 3.23's
The 2.8 can make a decent amount of power but I would assume there would have to be alot internal mods rather than just bolt-on parts... Some of which may or may not work with the 3.1.
Old Oct 16, 2006 | 07:08 PM
drdave88's Avatar
Engine: 6.0L
just about all the bolt ons for the 2.8 will work with the 3.1. i actually cant think of any that wont bolt onto the 3.1 right now. rockers, cam, UD pulley, t-stat, headers, valves, springs, pretty much anything that will go onto the 3.1, will go onto the 2.8. the only difference between the two was the stroke and from MAF to SD.
Old Oct 17, 2006 | 07:36 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If I could understand the questions and subsiquent posts for the OP, I might be able to answer them.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
