87 2.8 RS
Old Jun 14, 2008 | 08:49 PM
1st thirdgen's Avatar
87 2.8 RS
I am really looking for some help. I am not getting anywhere with my car. I have replaced the timing chain/sprockets, distributer cap, rotor, wires plugs, tps, maf, fuel pump, fuel filter, checked the egr, iac, and fuel pressure at idle. my car seems fine on start-up, revs fine and idles beautifly but if i put it in gear and try to drive i get about twenty feet before she just sputters. there is no power at all. The only other things i can come up with is the fuel pressure regulator, coil pick-up, coil, or the main computer. The ses light does not come on until she stalls eventually. At idle i have 35 psi of fuel but no idea about under load. could any of the above mentioned things that i have not tried cause these problems?
Old Jun 15, 2008 | 12:03 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 87 2.8 RS
clogged cat?
Old Jun 15, 2008 | 06:38 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: 87 2.8 RS
Dumb question, but do you have tranny fluid?
Old Jun 15, 2008 | 11:29 AM
88RS19's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V-6
Re: 87 2.8 RS
Isn't the fuel pressure supposed to be between 42 and 47 PSI??
Old Jun 15, 2008 | 11:46 AM
project89's Avatar
Re: 87 2.8 RS
only at 0 vacuum u can check it at idle by disconnecting the line that runs to the fuel pr regulator and then it should have 43-45psi of fp
Old Jun 15, 2008 | 01:24 PM
Re: 87 2.8 RS
I know that the cat isn't backed up because there is no cat. I thought that the fuel pressure was supposed to be between 35 and 45 i will look it up again in my haynes manual though
How do you check at 0 vaccum? Yes there is tranny fluid. when i say 35 psi at idle i just hooked the pressure guage up to the schrader valve and started the car. while it was idling, it read 35 psi.
Last edited by 1st thirdgen; Jun 15, 2008 at 01:26 PM. Reason: Automerged Doublepost
Old Jun 15, 2008 | 01:28 PM
project89's Avatar
Re: 87 2.8 RS
Old Sep 25, 2008 | 09:57 AM
Re: 87 2.8 RS
it ended up being a faulty fuel pump from the manufacturer
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
