3.1 haltech gmx ecu?
Old Mar 6, 2009 | 08:27 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
any one ever use the haltech e6gmx ecu on their 1992 or so camaro or firebird? this is the link to it: http://www.haltech.com/index.php?opt...d=20&Itemid=17
Old Mar 6, 2009 | 09:31 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: 3.1 haltech gmx ecu?
Heard of people using it, but only on serious high-dollar drag cars. It looks sweet, but is pricey and seems like way overkill on a stock v6.
Old Mar 6, 2009 | 10:32 AM
project89's Avatar
wow thats exspensive as hell and really not anything special except for the fact it may plug into the stock harness
for around 300 bucks u could just do a megasquirt,or u could just get all the stuff u need to burn chips for the ecm u have now
Old Mar 6, 2009 | 11:47 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
i was just asking because my local speed shop dont have any experience with the megasqurit system. they use the other all the time. and can u use the megasqurit while the engine is running to tune?
Old Mar 6, 2009 | 11:50 AM
project89's Avatar
megasquirt has all the features of that haltech and alot more.
yes megasquirt is real time tuneable
u can pick up a complete ms1 system with a harness for 311$'s from diy autotune
12x12 fuel and ign maps dual tables nitrous injection and just all sorts of features are built into it
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
Re: 3.1l dyno?
project89 you get your car dyno ed yet?
Old Mar 6, 2009 | 11:54 AM
project89's Avatar
Re: 3.1l dyno?
next weekend the 14th
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
i might just go with it. what extra sensors will i need to turbo charge mine. i seen your old post but could not find that.
Old Mar 6, 2009 | 11:57 AM
project89's Avatar
if u run it piggy back (fuel control only) u will need an extra air temp sensor and coolant temp sensor.
if u do full ignition and fuel control u do not need to buy and extra sensors
Old Mar 6, 2009 | 12:04 PM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
so all i will need is the ms1 wire harness system to run the fuel and ignition and the turbo stuff? does it plug into the old harness then into the ms1?
Old Mar 6, 2009 | 01:19 PM
project89's Avatar
no when u buy the harness it plugs into the ms1, then it runs out under the hood and u have to solder the connections, basically u cut the stock harnes and take it out and solder on the conectors onto the ms harness.
its really easy to do
Elephantismo
Feb 13, 2019 12:51 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
cking99
Sep 22, 2015 11:33 AM
