v6 cam?
Old Mar 11, 2009 | 08:15 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
v6 cam?
i have a 1992 camaro 3.1l it needs more power. i wanted to get some advice. i want to install a cam. it needs to be computer compatible. and anyone done theirs and what do u thing the power increase was.
Old Mar 11, 2009 | 01:44 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Re: v6 cam?
260 grind from Crane Cams, lots of people here are running it
Old Mar 11, 2009 | 06:58 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
Re: v6 cam?
How big of a cam helps with these V6's?
I am an LT1 guy, and while engine work isn't new, my V6 knowledge is lacking.
I think I am going to change the water pump next week during spring break, and might want to change the cam then.
How big with stock heads? At what point does the vacuum get affected?
Old Mar 11, 2009 | 07:22 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: v6 cam?
your pretty limited unless you can do some ecu tuning/prom programing. can you do that? check out www.summitracing.com they have lots of stuff.
Old Mar 11, 2009 | 09:54 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: v6 cam?
A cam change alone isn't going to net you a whole lot unless you get a pretty lumpy cam, but as restrictive as the stock induction is and being that it's a noninterference motor you can get away with alot of duration. The limit is valve lift with the stock heads. I think you're limited to ~.450 lift unless you cut the guides down. You really need to consider getting the exhaust opened up before you look elsewhere, that's where you're going to find the most gains. Then induction, heads and cam.
Old Mar 11, 2009 | 10:20 PM
project89's Avatar
Re: v6 cam?
260-2 grind is as big *** u want to go with tha stock ecm
call deltacams up 100 bucks for cam and lifters
Old Mar 12, 2009 | 01:42 AM
Engine: 2.8L - 6.3L
Re: v6 cam?
Yeah I have a bunch of exhaust leaks and was looking at some pacesetterse + my old 3" exhaust from my other car before a cam. Even if the cam only adds 10 hp, thats $10 per HP, not a bad ratio comapred to some other mods....
Old Mar 12, 2009 | 06:29 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: v6 cam?
Melling MTC-5 cam is about $100ish and is a decent cam, im happy w/ it.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
