throttle body question
Old Feb 27, 2010 | 03:09 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
what are this vacuum lines coming out of the 3.1 throttle body?
[http://webmail.aol.com/30746-111/aol...wMail&partId=2
the 3.4 doesnt have them
Old Feb 27, 2010 | 03:19 PM
Pillsbry10's Avatar
Re: throttle body question
i could really use a good picture of a fully assembled 3.4 motor as well if anyone has one
Old Feb 27, 2010 | 04:49 PM
Drew's Avatar
Hotlinks to photos stored on your AOL mail don't do us much good. Save the files, and then use the attachment feature to upload them here. Or you could upload them to photobucket and then hotlink to that location.
But in general, you've got the connection to the fuel pressure regulator, and the charcoal canister.
Old Feb 27, 2010 | 05:37 PM
Pillsbry10's Avatar
wow dont know why i put those on there like that...how about now lol
i guess the real question is can i relocate them?
Old Feb 27, 2010 | 08:07 PM
Drew's Avatar
https://www.thirdgen.org/forums/prob...mages-tgo.html
Old Feb 27, 2010 | 09:10 PM
Pillsbry10's Avatar
Pictures aside... Can those lines be relocated?
Old Feb 27, 2010 | 09:37 PM
Pillsbry10's Avatar
been a long time since ive uploaded pictures...i seem to remember it diffrently lol
Attached Thumbnails throttle body question-tb-pic.gif   throttle body question-get-attachment.aspx.gif
Old Feb 27, 2010 | 09:42 PM
Drew's Avatar
Sure! The FPR can just tap into one of the nipples on the plenum. Just make sure the MAP sensor is the only connection to it's own nipple, and the brakes are on their own, the other connections are fine. The charcoal canister line just routes excess vapors back to the engine to be burned. You can probably just eliminate that line, or route it into the air intake duct. Usually if you look at the throttle body you can see where the port goes.
Old Feb 27, 2010 | 09:49 PM
Pillsbry10's Avatar
i made a spot for the map sensor when we coated the intake i should have all the same connections on it as the orginal intake did... and i can just put the fpr on any of the other vacum lines then so long as its not the map?
on the pass side valve cover the line that runs in there off the intake tube, i used the 3.4 valve covers and that tube wont reach the valve cover can i elminate that and just plug the whole on the valve cover or put in something else?
Old Feb 27, 2010 | 10:02 PM
Drew's Avatar
The FPR just needs a vacuum signal. The MAP needs a clean signal, and the brake system should probably have a somewhat dedicated line. The valve cover hose is part of the PCV system, and you'll want to connect it back to the intake at some point.
Old Feb 27, 2010 | 10:24 PM
Pillsbry10's Avatar
i should have all the fittings in the intake for that so i think im good... i have a post on here somwhere from forever ago that shows the fittings.
i suppose i could just lengthen the tube somehow so that it reaches, i seem to remember seeing someone just put a little filter on the valve cover instead.
Old Feb 28, 2010 | 02:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I currently use a rubber vacuum line for mine. May not last, but at least I don't have to fight with that valve cover elbow when I need to remove the bellows for something. It seals pretty well at the elbow, but I put the stock hose clamp back on the bellows just in case.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
