Help how to change cam bearings 2.8
Old Nov 18, 2010 | 03:48 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
How to change cam bearings???
2.8 engine!
http://www.summitracing.com/parts/FEM-1492M/
Old Nov 18, 2010 | 08:11 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: Help how to change cam bearings 2.8
I don't know, but I think I know who does:
http://compare.ebay.com/like/1105895...=263602_304662
Old Nov 18, 2010 | 08:44 AM
Car: Camaro 1988
I have this repair manual http://cgi.ebay.com/ebaymotors/82-83...item5d277d4ee6
But, not information!
Old Nov 18, 2010 | 09:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's pretty straightforward... remove the cam, knock out all the old bearings and drive the new ones in with the installer.
What's wrong with your bearings?
Old Nov 18, 2010 | 09:08 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Cam bearings are usually only replaced during a full rebuild, due to needing the engine out of the car and on a an engine stand, to remove and install the cam bearings.
Old Nov 18, 2010 | 09:09 AM
mightymaro94's Avatar
Old Nov 18, 2010 | 03:32 PM
Car: Camaro 1988
of 22 years!
I have new cam edel-3790
https://www.thirdgen.org/forums/v6/593129-camshaft.html
and new piston,intake monifold,carb 4-bbl....
Old Nov 18, 2010 | 04:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The manual that Jensen linked to is the best manual (I have both).
You'd need something like http://www.summitracing.com/parts/CCA-5312/ . If you're just installing the cam, your current 22-year-old bearings should be fine because camshafts aren't high-load parts; the bearings don't wear out (unless the engine had no oil).
When the engine's out and you're doing new pistons/bore/hone/etc, when you install new bearings, make sure the oil feed holes line up; otherwise you'll ruin the bearings and the cam.
As was said before, cam bearings are usually replaced during the machine work on the engine, especially because the shop already has the tool.
Old Nov 18, 2010 | 04:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
22 years is nothing in a cam bearing's life, if there's no scratches or embedded debris.
The other reason they're done while the engine is at the machine shop is because the hot tank solution would dissolve the soft metals in the bearing and they'd need to be replaced afterwards anyway.
Old Nov 18, 2010 | 06:12 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
On average, the cam bearings do not get changed unless they are beat up or have copper showing. To replace them, you need the special install tool and you have to make sure you line up the oil holes right or you will burn that engine up in no time. They also must be driven in straight. I would just have a shop do it. It does not cost much and you know there will be no problems.
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
gwade12
Aug 8, 2015 08:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
