Gear question.... (V6 board)
Old Oct 18, 2000 | 10:23 PM
SlowCamaro88SC's Avatar
to those who know the V6's...
what would be the best and highest gears to put in my '88 camaro.
3.42 automatic open diff.
that's the stock gearing.
gas mileage doesn't matter, as the mileage kicks *** already..
4.10 seems to be the word around here, but what about 4.56's?
remember peak hp is @ 4900 and peak torque is @ 3900.
quite a bit higher than the TPI's. and it seems that the TPI boys don't go over 3.73's
so i'm thinking the higher gears would help a 2.8 get up and go...
help me decide guys and gals....
Old Oct 18, 2000 | 10:42 PM
3.1 firebird's Avatar
I have 3.23;s and I just ordered 3.73's , so the gas mileage isnt affected to much. This should give a good bump in performance........I bet 4.10's are better though if you dont mind getting worse gas mileage. I cross the 1/4 mile marker turning 4000 RPMS, so I need more gear since the peak is around 5000 rpm.
So what I;m saying is GET 4.10's! (if you dont mind bad gas mileage....)
Old Oct 18, 2000 | 10:52 PM
hey, with a V6, the mileage is already good, you can't lose too much. it's looks like a v8, so why not get v8 mileage?
what about 4.56's?
Bright Red 88' Camaro SC, Rare Spoiler
2.8, 3.42 Open Rear
TCI 3200 RPM Stall TC
B&M Transkit
Sawed Airboxes
83 Z/28 Hood (w/ Functional Scoops)
Ground Effects Red in front, fade to silver on sides
Custom Painted Stock "Z/28" Rims
2.5" Dynomax Catback (Where's the Cat? Must have fell off)
IROC Gages
IROC Taillights
Foglamps
BFG Radial T\A's
235/60/15 Front
275/60/15 Rear
And of course, a loud stereo
Old Oct 19, 2000 | 12:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
4.10? 4.56?? Damn those gears seem way too low to me! You'll be running out of gear quick with an automatic tranny..
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 19, 2000 | 08:12 PM
94Camaro's Avatar
Car: 1994 Chevy Camaro
Engine: "3400" 207ci V6
Transmission: Tremec 5 Speed (T5)
tom is right. i have heard of a guy that got the 4.10's in a 1996 camaro v6 (3.8L) and he cant go over 80 mph because of the rev limiter kicking in (the speedo gets thrown off that much) cause his rpms are that high. i would say no higher than 3.73. i have 3.23 in my 94 camaro and it already packs a pretty good punch launchwise.
-- Russ
Old Oct 19, 2000 | 09:03 PM
Brian K's Avatar
See a long time ago there used to be a guy on this board that had 4.10's in his 86 bird. His chip took off the rev limiter and he had 235 60 R15's and loved the change... He said it would go and was glad he went 4.10's over 3.73 cause it was a more drastic change. I plan to run 4.10's in my 86 camaro with a locker.... Seee you also have to consider tire diameter in this...
Old Oct 20, 2000 | 12:34 AM
our cars have a rev limiter? I never tried to find out. hmmmmm. i need a v8 though, my ma's '96 monte carlo z34 is waaayyyy faster...
Old Oct 20, 2000 | 09:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The rev limiter appeared on the 4th generation f-bodies. The computer uses it as a speed limiter. Our cars are "supposed to" have a speed limiter at 112, but my highest speed is 137- that might be due to either the ADS superchip, or that I lucked out and didn't get a speed limiter.
Armored91Camaro
Aug 25, 2015 12:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
JPrevost
Dec 18, 2001 11:08 AM
TRAXION
48
Feb 15, 2001 07:11 PM
91Bird305
Oct 22, 2000 06:51 PM
