Throttle body spacer
Car: 1991 Z28
Engine: 5.7 TPI
Anyone interested in one of these? I know some guys swear AT them, saying they either don't work, or they SUCK, but if anyone wants one, let me know- I am doing the plenum spacers that I mentioned next week and can make some of these too...
I am thinking $39 each, 6061 aluminum- anodizing extra.
Car: 1991 Z28
Engine: 5.7 TPI
Re: Throttle body spacer
I will include shipping. I just made one for myself and will be picking it up from the anodizer's on Tuesday. I will post a picture...
Guest
Posts: n/a
Plenum spacers effectively increase the plenum volume. So guys trying one on a 4.8L LSx ( LR4 ) probably will hate the spacer, since they already have plenty of volume. But guys trying them on a 6.0L LSx will probably get much better results.
I expect the same deal here: they should be more helpful to those of us with 3.4L swaps than to those of you still stuck at 2.8L.
I'll probably try making 2 of my own out of 3/4" plywood, using the old gasket as a pattern, for my initial testing.
Car: 92 Camaro RS 25th Anniversary
Engine: 3.1L V6
Transmission: 5 speed
Axle/Gears: 10 bolt with 3.42s
ok, i would like to see the pics, if it will help my 3.1L then i am in , i also was thinking, i could put my nitrous wet nozzle in there too!! it might work. for 40 bucks i might take the chancs, how much more is it to get anodized?
Car: 1991 Z28
Engine: 5.7 TPI
The problem with anodizing, powdercoating etc is the order minimums. If I am doing a bunch it is cheap. The other issue is the waterjet leaves a textured surface where it cuts that needs to be sanded, so there is a bit of labor there that can make it cost prohibitive. It took me about an hour or so to sand mine smooth so that it looked polished- that makes the anodizing look better. You will be able to see what I mean in the photos. I should be picking the parts up on Tuesday I think, so I should have photos up on Wednesday. And it would be a perfect place to mount your nitrous nozzle!
Engine: 3.1L V6
well then i would buy one ant i hve a buffing wheel and rouge and i can polish it like chrome, so never mind the anodizing.
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Are these available still? If so, how much for a red one?
besides this being useless how are u going to correct the tv cable since a throttle body spacer will make the tv cable to short to work properly
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
