black spark v6 3.1
Old Aug 20, 2011 | 01:29 PM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
black spark v6 3.1
no check engine!
New oxigen sensor!
Old Aug 21, 2011 | 09:14 PM
84CAMARO28inFL's Avatar
Re: black spark v6 3.1
Id love to offer advice, but i do not know what "black spark" is.
Does the car run?
Old Aug 22, 2011 | 02:38 PM
Car: Camaro 1988
Sorry my english!
Spark Plug black, I think it is a rich exhaust
Does the car run?
yes, but very bad
Old Aug 23, 2011 | 02:34 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
When's the last time the car's had a tune up?
Old Aug 23, 2011 | 03:37 PM
Car: Camaro 1988
i bay engine 3.1 for swap my car!
6-12 m.
Old Aug 23, 2011 | 03:47 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Is the black stuff sooty(like powdery kind of, particles fall off if you touch or rub it) or is it oily/greasy? The former means you are running rich(typical of these engines) the latter indicates bad valve stem seals or piston rings.
Old Aug 23, 2011 | 03:57 PM
There was a fair amount of oily slime around my spark plug holes, but my carb is out of adjustment and i know that.. could that make more "running rich?" And they call that "soot," right? Ive done iston soaks on my engine with carb and choke cleaner, sprayed in to the spark plug holes. Smoked for a bit, then when that cleared up, nice and smooth-running.
OP, does it consistently blacken up the plugs?
Old Aug 24, 2011 | 03:35 AM
Car: Camaro 1988
Yes ''soot''!
how to test the MAP???
I guess it could be a temperature sensor?
Old Aug 24, 2011 | 06:30 AM
ex-x-fire's Avatar
Test fuel pressure & leak down rate.
Put a tee into the vacuum hose that goes to the map sensor, hook up a vacuum gauge. It should be above 16.5" at idle, with a smooth needle sweep. Have the engine scanned for live data.
You can test the coolant temp sensor, you need an ohm meter, thermometer, & a pan of water (heat it up slowly to 220 degrees), note the ohms at different temps. Google GM Coolant Temp Sensor Values for the ohm/ temp readings.
Old Aug 24, 2011 | 08:54 AM
Car: 1988 camaro
Engine: cammed 3.1
Reni-Camaro, if you need the coolant temp sensor values you can pm me and I'll send you an attachment with the chart.
Elephantismo
Feb 13, 2019 12:51 AM
Sincat_23
Mar 22, 2001 11:23 PM
Sincat_23
Mar 20, 2001 06:12 PM
Sincat_23
Feb 15, 2001 11:47 PM
steven
Nov 6, 2000 04:19 PM
