newly rebuilt engine won't crank
Old Jan 19, 2013 | 10:53 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
Got my engine and tranny back in the car.
Tried to crank it over and starter engages, sounds like it is struggling to move but engine is not moving.
I can turn the engine over by hand with a wrench by the crank bolt.
Any ideas what's up
Maybe starter not in properly........ did I need time shim it differently.
Rhys
Old Jan 19, 2013 | 11:42 PM
project89's Avatar
Re: newly rebuilt engine won't crank
Any ideas what's up
Rhys
unplug the ignition coil and try to crank it again , if the motor turns over that means ur firing orde ron the plug wires is wrong and or ur timing is way advanced
starter make anykind of grinding noise or anything like that
Old Jan 19, 2013 | 11:59 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
The starter makes a grinding noise. The engine is not turning at all like it's siezed.
Maybe the starter is not in properly. Could I have put it in wrong ?
There was a dog leg shaped flat metal strip tab that I put between the starter and the block - is that the right place for it to go ?.
Old Jan 20, 2013 | 03:17 AM
project89's Avatar
yeah thats a starter shim itake it back out i never had to use one with any of my v6's chances are he shim mived the starter pinion teeth away from the flexplate to far for it to engage properly
Old Jan 20, 2013 | 06:49 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Did you wire up the starter properly? On the sileniod...
Old Jan 20, 2013 | 10:26 AM
ex-x-fire's Avatar
Check the ground cable & battery connects & state of charge of the battery.
Old Jan 20, 2013 | 03:20 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
Hey
took the starter out to bench test. spins nicely and fast.
gear click out and back nice and fast.
just to make sure, does this plate go in between starter and block. looks like it does and the dirt spots match up.
gonna put it back in now I cleaned all connections
Rhys
Posted from Thirdgen.org App for Android
Old Jan 20, 2013 | 03:47 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I used that shim or whatever it is also when I got a new starter.
Old Jan 20, 2013 | 09:36 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
I put the bolts in half way to see if it would crank and it did.
also did not have it grounded to the engine properly as I have lost the ground bolt.
battery was weak so jumped it. cranks fast and got it started. hooray.
Engine sounds tappy. Could it maybe have not pumped oil to the lifters?
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
