Ronal R15 questons
Old Oct 15, 2008 | 05:36 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Ronal R15 questons
I bought Ronal R15 wheels for my TA. I did search but did not find exactly what I was looking for.
1) How big spacers do I need?
2) Will I run into some problems with 275/40 both front and rear?
3) Whats the biggest tire size I could use without problems?
Old Oct 15, 2008 | 06:00 PM
Stephen's Avatar
Car: 87 GTA
Re: Ronal R15 questons
Spacers can only determined by knowing what your backspacing is. Until then, we can't tell you anything.
I have 275s front/285s rear no rubbing. But until your backspacing is determined, we won't know if you will have any problems.
Biggest tires used can only be determined until we know your backspacing. Until then, its all a guess. Get back to us with a measurement on the backspacing & we can go from there.
Old Oct 15, 2008 | 06:14 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Well, the wheels havent arrived yet so I dont know. I am sure there are some with the Ronal R15 who can answear the questons.
Old Oct 15, 2008 | 06:19 PM
Stephen's Avatar
Car: 87 GTA
I'd be willing to bet they are available in more than 1 width and backspacing.
You didn't even say if they are 15", 16", 17", or 18"....Or other....
My Snypers are direct fits. Snypers coulda been had in 8"
& 9" width. In a 3rd ge or 4th gen backspacing....Meaning there are DOZENS of combinations.
I was just trying to help....
Old Oct 15, 2008 | 06:38 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
You could be right but I havent heard they came with different backspacing. I am talking about the Ronal R15 17x9.5 wheels, the same that where on the Firehawk (and some say they where designed for the third gen).
When I was searching some said that they didnt need spacers and other talked about thin spacers.
I know you where only trying to help and took no offense in your reply, I hope that my reply whas not offensive (it was not meant to be).
I wont get my wheels home untill christmas, I want to order the spacers before if I have to buy them (it takes some time to arrive) so I hope I will get some answears.
Old Oct 15, 2008 | 06:42 PM
Stephen's Avatar
Car: 87 GTA
If they are the Firehawk wheels, I would think you'd need nothing. The stock Firehawks needed nothing.
Old Oct 15, 2008 | 07:27 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I have Ronal R15.
I use a 5/16 spacer on both fronts because the tie rod touched slightly on one side only.
The Firehawks had Brembo brakes (I think it was) which is why they may not have required spacers.
I have BFG KDW 275/40/17s on all four corners w/out problems. The fronts rub slightly on the plastic fender liner but nothing to worry about.
AFAIK R15 are the correct spacing for our cars as they were pretty much designed for thirdgens.
Some came with spacers some didn't. I got mine from SLP and they didn't pack the spacers so I had to buy them.
Good rims and look good on our cars - only thing is that they're slightly heavy and somewhat limited for brake upgrades. 1LE will fit, probably C4 and I guess the original Brembo setup.
Maybe Ed has figured by now which brake setups can be used.
I would say max on the front unmodified is 275/40/17.
I would also suggest getting 275/40/17 on the back so you can switch them with the fronts after the backs start to wear. I believe this size on all four corners is about optimal for the car anyway for road course use so same should apply to street although drag racing is another matter.
Old Oct 15, 2008 | 09:56 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I wonder how they compare in weight when compared to, say ZR1s and 2" spacers. I'd really like to get a set of 17x9.5s that don't require spacers. But then, I'd have to get a 3rd Gen rear end with posi/disks lol.
Old Oct 15, 2008 | 10:06 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Yeah, they'd be stickin out real good with the 4th gen rear..lol
Old Oct 16, 2008 | 05:41 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Originally Posted by George
I have Ronal R15.
Thanks a lot, this answears the questions
Old Feb 16, 2009 | 02:27 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I bought them from the Ronal place over in Huntington Beach and I was told that I didn't need spacers and I was ready to go. I do get light rubbing on the front as well but the car handles so much better. And if you don't have one yet on your car, get a "wonder bar".
Old Feb 16, 2009 | 03:53 PM
Abubaca's Avatar
I researched the R15 waaaaay back when. From what I've read "on the record" you don't need spacers. ...."off the record" several people report minor rubbing.
Old Jun 24, 2009 | 01:26 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I need to make a correction. I ended up getting spacers for the fronts as they were rubbing on the steering knuckle. Got it done when I had the car alligned. Turns out if you have the 1LE brakes, you don't need the spacers as that system sticks out more than the stock system our cars came with.
Old Jun 24, 2009 | 02:40 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
No rubbing at all with the Baer brakes either.
Old Jun 24, 2009 | 03:55 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Cool. I'm due for new brakes anyway. I'll check them out.
Old Apr 20, 2013 | 02:38 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
I have them on mine with the 5/16 spacers
Old Apr 29, 2013 | 03:24 AM
87bigbirdy's Avatar
Car: 87 formula
dam ...someone needs to remake these wheels soon.i need them for the final touch
Old Apr 29, 2013 | 08:17 AM
85_ZED28's Avatar
Car: '85 Z28
10% off right now at summit racing:
http://api.viglink.com/api/click?for...13672414006873
https://www.thirdgen.org/forums/whee...onal-r15s.html
Old May 29, 2013 | 12:37 AM
87bigbirdy's Avatar
Car: 87 formula
found a mint set of orginals!! picking them up friday!!!!
Old May 29, 2013 | 11:33 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
My experience with the R15's... Since I haven't done my brake upgrade yet, I had to run a 5/16 spacer, along with grind the tie rods and front struts to clear. I am running Tokico Illumina, and they were close so I clearanced them. When I upgrade to 13" Wilwood kit, I don't think I am going to need to run a spacer after as it pushes the wheels out a bit.
Old May 29, 2013 | 01:32 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Make 100% sure before you buy that Wilwood kit that the brake caliper face clears the back of the Ronal spokes. There is not an overabundance of clearance with the design of those wheels.
Old May 29, 2013 | 01:43 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I don't really have a ton of options when it comes to 13" brakes, so I am going to have to go with it. If I don't like the way things work out, then I will pick out a new wheel and go with some 18's. The reason for me going with the Wilwood kit is because the caliper is smaller. I know the Baer 13" will not work as the caliper is too tall/wide.
I'm really not too sure how I feel about the Ronal wheels anyhow. I got a good deal on them and decided to get them until I find something I like better.
Old Jun 4, 2013 | 07:15 AM
87bigbirdy's Avatar
Car: 87 formula
how would u go about cleaning/waxing these wheels? what product is best? ty
Old Jun 10, 2013 | 12:31 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Im wondering and this might be a stupid question but would the clear LS1 front and rear brakes as if not Im gonna have to look for different rims or keep my GTA's
Old Jun 10, 2013 | 01:38 AM
87bigbirdy's Avatar
Car: 87 formula
front driver side tie rod appears to b rubbing ever so slightly though.. not sure.if i need an alignment or what but these wheels are.sweet
Old Jun 10, 2013 | 03:05 AM
87bigbirdy's Avatar
Car: 87 formula
ok so now i need 5/16 spacers for the front? do the fact the inner rim is slightly hitting the tie rod..any helo would b great!! also to find out who makes these spacers.
Gary@Ronal
Mar 16, 2003 10:01 PM
Gary@Ronal
Jun 25, 2002 03:03 PM
Gary@Ronal
Jun 16, 2002 12:30 PM
84 Z-28 350
May 31, 2002 01:19 AM
formul8!!
Feb 12, 2002 09:45 AM
