Alternator support after stealth ram install
Car: 2003 z-71 Silverado, 1988 Iroc-z
Engine: 5.3, 5.7
Transmission: 4L60e, 700r4
Axle/Gears: 3.73, 3.31
Hello,
I just installed the HSR on my camaro and the old alternator support doesn't fit. It is the support bar that goes from the alternator to the water neck mounting stud/bolt. I figured maybe an alternator support from a tbi of the same year might fit but I can't seem to find one. Any body have any part numbers?
Thanks!
Thanks!
Re: Alternator support after stealth ram install
I dont run a SR but when I added an aftermarket intalke I needed to weld up a bracket to utilize the header bolts as a source of support.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I didnt use the metal bar on mine.
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Dont need the metal bar from the top of the alt to the intake remove it as long as you got the two alt bolts in at the top ad bottom ur find
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Hello,
Thanks!
Thanks!
http://www.summitracing.com/parts/SUM-G4017/
I used stock alt support bar. Just cut to lenght and rotated the end a bit to align and welded. #1 header bolt with a threaded coupling (female to female) to threaded rod to head with another threaded rod at opposite end of coupling with a nut. I can post a pic?
Mine is a serpentine car 88-92 not the 87 and older. Dont know if they have to have it or not.
Engine: 5.3, 5.7
Thanks for the tips!
I actually ended up using a 1/8" thick piece of steel that I found in our scrap pile at work. Cut it to proper length, twisted it with a pair of channel locks, since the ends oppose each other at 90 degree angle and drilled holes in the ends. I will post a pic of this later when I get a chance.
Thanks!
Thanks!
Car: 87 Iroc-z
Engine: 383 TPI
Transmission: 700 R4
Axle/Gears: 3.27 posi
87sleeper...where did you get that upper radiator hose and what is it originally for? Thanks.
Engine: 5.3, 5.7
I believe it was the hose for a 1988 firebird formula with the Tbi intake.
Car: 1992 RS B4C
Its from a Monte Carlo V8 86 or 87. I think its the same for both years. I had to cut about 1 3/4" of one of the ends to get good bends. It fits perfect.
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
L98GTA87
Aug 11, 2015 06:55 PM
