How will this sound...
Old Mar 7, 2004 | 02:08 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I have pretty much decided that I am going with the eD 10kx sub and a JBl Powervalve 300.1. The sub will probably be in about a .5 cu ft enclosure.
Compared to 2 12" Polk 165 wrms and a Jensen amp pushing them at 85w rms in an enclosure that took the entire well (not just the bottom part) with no baffles.
What do you think, will my new set up have better SQ?, SPL?, both?, neither?
Old Mar 7, 2004 | 05:57 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
i think the new setup will have better SPL and SQ...because although you're downgrading your cone area, you're buying a better quality sub and its properly powered.
Old Mar 7, 2004 | 07:07 PM
9177's Avatar
I doudbt you'll gain any SPL but you should have good sq.
Old Mar 8, 2004 | 01:14 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if you're after more spl you could port your box
Old Mar 8, 2004 | 04:02 PM
I'm not to knowledgeable in the porting department. What would be involved in porting the box? Just a bigger box with a certain sized hole in it?, Baffles? what.
Old Mar 8, 2004 | 05:23 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
well first you would have to check in with ED to make sure that sub will work well in a ported box. Then they will suggest the best box for it.
Old Mar 8, 2004 | 05:25 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
this is the box ED recommends for that sub
im not sure i agree with the design of it...the port takes up way too much of the box. But thats the manufacturer designed enclosure so they would probably have more experience with it than i do
Old Mar 8, 2004 | 08:23 PM
Yeah. I knew about that box, but I really don't want to use that much room. If the spl is even close to the same loudness I'll be happy, so I think a sealed box will work well for me
AllShowNoGo88
Mar 27, 2015 06:19 PM
coptzer
Nov 25, 2014 07:49 PM
Neal301
Nov 11, 2013 11:01 AM
CD MaroMan 91
Car Audio
Mar 29, 2003 11:42 PM
pvknight
Oct 25, 2000 12:16 AM
