Hidden Aux Input
Old Dec 30, 2012 | 11:02 PM
ynk1121's Avatar
Car: 90 IROC, 95 Vette
Hidden Aux Input
Anyone looking for some ideas to keep it stock looking this is what I came up with. Found a scrap piece of metal in the garage and made a clip. Easy to get to and not noticeable. Best of all, no cutting or drilling the car involved.
Attached Thumbnails Hidden Aux Input-img_20121024_225214.jpg   Hidden Aux Input-img_20121024_225236.jpg   Hidden Aux Input-img_20121025_143609.jpg
Old Jan 4, 2013 | 11:42 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Re: Hidden Aux Input
Awesome idea! looks great!
Old Jan 4, 2013 | 12:07 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I like mine better... see it?
Old Jan 4, 2013 | 02:58 PM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
Not at all....do show and tell!
Old Jan 4, 2013 | 03:19 PM
58mark's Avatar
this will give the answer
Old Jan 4, 2013 | 05:44 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Why not run a full length cable somewhere hidden?
Im not sure I see the purpose of essentially "adding" a connection where one is not needed..
Old Jan 7, 2013 | 05:34 AM
ynk1121's Avatar
1) It's needed to automatically switch between auxiliary input and the radio. Without using the female jack changing it over when plugged in, there would need to be a switch somewhere. I'm going for a factory look. I didn't want a switch anywhere.
2) I don't always use it. Often times on short drives I listen to the radio. I don't want any unused wires laying around.
3) If it was only an mp3 player stuffed in the arm rest it would make some sense, but I use my phone with a car dock stuck to the windshield because it does double duty for music and navigation. There's no good way I could think of to hide a wire on top of the dash or one long enough to reach there. With this, I plug the coiled wire from the dock into the jack when I'm using it, and store it away when I'm not.
Old Jan 7, 2013 | 05:36 AM
ynk1121's Avatar
Originally Posted by 58mark
That's a nice way of doing it.
Old Jan 11, 2013 | 06:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Jan 24, 2013 | 05:44 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Hey **** you!
For having a badass radio that I want
Old Jan 30, 2013 | 09:08 AM
Jk_Under's Avatar
Engine: 305 5.0L
I just put a tape deck in my moms 89, she loves using her phone music on the radio lol.
Old Jul 10, 2013 | 11:17 PM
JOEM's Avatar
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
SLICK!!!!!!!!!!
Old Aug 19, 2013 | 02:10 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
How is that wired in?
Old Aug 19, 2013 | 03:33 AM
ynk1121's Avatar
Here are the step by step instructions I used:
http://eurosportvr.com/misc/ipod%20input/index.htm
Old Jan 4, 2018 | 04:21 PM
KCG's Avatar
KCG
Car: 89 IROC
Bumping an old thread cause I'm hoping someone has these instructions.
The link is dead.
Old Jan 4, 2018 | 05:18 PM
Ct1987's Avatar
This might help you.
Louis
http://www.s10forum.com/forum/f27/ho...-heavy-510517/
Old Jan 4, 2018 | 06:42 PM
KCG's Avatar
KCG
Car: 89 IROC
Thanks for the link. Just skimming thru it, it sounds like you need to run the CD player to have this work.
Old Jan 4, 2018 | 07:37 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
That’s awesome 58Mark.. I want to do that so I can put my stock radio back in.. the previous owner put an Alpine with an iPod cable and the only thing that keeps that radio in is the ability to play my awesome 80s playlist on my iPod.. he gave me the stock radio and speakers too.. I used to like the look and sound of the stock system..
Old Jan 8, 2018 | 05:15 AM
KCG's Avatar
KCG
Car: 89 IROC
I've searched all weekend and can't come up with a thread that shows how to add an aux input without having to either have a CD or cassette running to make it work. Has anyone?
Old Jan 8, 2018 | 08:43 AM
Ct1987's Avatar
KCG, Before I did my conversion, I spent countless hours trying to figure out how to do it without having the cd or tape active. Could not find any info.There are guys on the net that convert radios without the cd or tape, so there must be a way. I would like to find out myself how to do it.
Louis
Old Jan 8, 2018 | 12:36 PM
KCG's Avatar
KCG
Car: 89 IROC
ok thanks Louis. I'm going to keep searching. We'll come up with something
Old Jan 8, 2018 | 01:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Something like this?
https://www.thirdgen.org/forums/car-...-mp3-jack.html
or this.
https://www.thirdgen.org/forums/car-...aux-input.html
Old Jan 8, 2018 | 02:38 PM
KCG's Avatar
KCG
Car: 89 IROC
yeah found both of them, unfortunately the images don't work for me on the first one. The second one is for CDM radio. Not sure if thats the same as mine or not.
Old Jan 17, 2018 | 08:39 AM
ThePain's Avatar
Car: 1992 RS
Has anyone noticed the hole in the bottom of the dashpad? Near the center? Not sure if everyone else has it but that always looked like something should be there, but it would make a good hidden aux spot
Old Jan 17, 2018 | 12:51 PM
Drew's Avatar
It's an ashtray/shifter light on some thirdgens.
Gm used the tiniest bulb, and a goofy lens, so that basically it doesn't do anything. But that's what it is.
Later cars used a self contained light with a plastic lens that snaps in with a 1/4 turn lock. 90-92 Firebirds all have a hole for the light assembly, in the center switch panel, but most don't have anything in the hole since it's redundant with the light in the rearview mirror.
cheesehomer
Dec 31, 2015 08:48 AM
Linson
Oct 1, 2015 09:50 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
gta892000
Sep 16, 2015 12:37 AM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
