Alpine 7863!
Old Dec 20, 2001 | 02:16 PM
jobryan26's Avatar
Alpine 7863! Jim!!!!!!!!!!!!!!!!!!!!!!HELP!
I just swapped my Kenwood Excelon 615 for an Alpine 7863 Headunit. I don't have a users manual so I have a questions. There is a menu somewhere that controls Crossover, Center Bass & Treble, and etc. How do I get to it? Thanks John
Here's a pic of it
Old Dec 20, 2001 | 03:31 PM
383 Smoka's Avatar
Push the circle dial in....
Old Dec 20, 2001 | 03:34 PM
jobryan26's Avatar
It's not showing up in that menu is it because of that Ai-net switch under the receiver?
383 Smoka's Avatar
It also has an independent sub control that most people dont know about... Hold the blue button in (the one thats beside the circle dial) until it says SUB LEVEL.. Than u can choose 1 2 or 3 and it gives u some more bass....
Old Dec 20, 2001 | 03:35 PM
jobryan26's Avatar
Yep I found that one for the BBE level but that wasn't it either
Old Dec 20, 2001 | 03:36 PM
jobryan26's Avatar
Only thing showing up in that circle button is BBE on/off, Bass level, Treble level, Fade, Balance.
Old Dec 20, 2001 | 03:45 PM
jobryan26's Avatar
I just found the Bass Width and center freqency. 1st green button you hold it in but that was all in there.
Old Dec 20, 2001 | 03:48 PM
383 Smoka's Avatar
Are u sure it has the crossover option? I have the 7861 and it doesnt have that option... The 7863 came with it? I didnt think it did.. They told me the only difference between the 7861 and 7863 is the appearance?
Old Dec 20, 2001 | 03:53 PM
383 Smoka's Avatar
Try that AI-NET switch...
Old Dec 20, 2001 | 04:11 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Try this..............
http://www.alpine1.com/html/D2_n_1_n_n.html
It's the owner's manual for your HU.
It may not let you in. If it doesn't, let me know.
AJ
EDIT: Well all that link does now is take you to the HomePage.
Give the thing a few minutes to download and then I'll email it to you. OK? It'll be an Adobe Acrobat Reader progam file. Do you have that program?
AJ
Old Dec 20, 2001 | 04:12 PM
jobryan26's Avatar
Yea and it has switchable illumination phase switch for subs and etc. but I can't find none of that.
Old Dec 20, 2001 | 04:13 PM
jobryan26's Avatar
AJ
Won't let me in it's taking to the front of the website
Old Dec 20, 2001 | 04:16 PM
AJ_92RS's Avatar
Look @ my edit above.
AJ
Old Dec 20, 2001 | 04:17 PM
jobryan26's Avatar
AJ
KICKASS!
Old Dec 20, 2001 | 04:33 PM
AJ_92RS's Avatar
It's on it's way.
Let me know if it worked or not.
That MSN is a lot faster at transferring files than Yahoo is!!!!!!!
I just spent about 5 min. trying to get Yahoo to do it.
MSN/Hotmail took about 5 sec.!!
AJ
Old Dec 20, 2001 | 07:11 PM
jobryan26's Avatar
K found everything but how to switch the illumination?
Old Dec 20, 2001 | 09:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The illumination isn't switchable on this model. You've got to live with the green.
Just like for the bass adjustment, you hold in the green button until you see the bass. THen you use either the volume **** or the track up/down buttons to scroll through the bass, treble & crossover adjustments. I think you use the track up/down buttons to scroll and use the **** for adjustments. If you don't have it figured out by tomorrow, I'll go out to my GTA and refresh my memory.
Old Dec 20, 2001 | 09:50 PM
jobryan26's Avatar
Err! I was searching the web to see what kinda stuff it had and all the sites I went to said it did but I sure didn't find it and I guess that's a good reason why. Hey Jim when I turn on the SW in the menu I lose alot of my Sub output, but when it's off it's like 5-10times louder Ihave to turn up the SW level to like 10 to equal the output of it turned off. Is yours like that and any reason why?
Old Dec 21, 2001 | 07:04 AM
Jim85IROC's Avatar
I don't use the sub output because I let me amp handle the crossover task. I'm guessing that you're turning on the crossover, and it's probably set at a low frequency, so you're cutting out most of the bass.
Old Dec 21, 2001 | 03:47 PM
jobryan26's Avatar
I've got mine setting like that right now and it sounds best. I'll tinker with it alittle more.
kairles
Oct 26, 2015 09:13 PM
Cripley
Aug 17, 2015 03:35 PM
Jim85IROC
Car Audio
Dec 17, 2000 10:28 PM
stingerssx
Car Audio
Dec 1, 2000 03:09 PM
Harley61
Car Audio
Nov 16, 2000 07:41 AM
